06-18-2018, 10:21 AM | #1 |
Drives: 2016 1SS M6 Join Date: Jan 2018
305/ tire fitment on factory wheels. Big problems!!!
I stuffed some used 305 NT555 drag radials on the camaro and this is what happened. Stay tuned and I’ll show you how I repaired the harness and relocated it. Very easy relocation process. No wheel spacers required.
06-18-2018, 10:28 AM | #2 |
BAMF SS
06-18-2018, 01:25 PM | #3 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
It's a known issue.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
06-18-2018, 01:28 PM | #4 |
Drives: SS-6-SPD Join Date: Jan 2017
that was given... almost relocate the harness... it's easiest thing in the world to relocate it lol.. unclip move and zip tie lol.
06-18-2018, 01:42 PM | #5 |
After I soldered and repaired the wire, I relocated the harness here.
Stupid location for a fuel pump harness in my opinion. Sorry I did not take the pictures in landscape. |
06-18-2018, 01:46 PM | #6 |
5mil spacers fill it out better.
06-19-2018, 07:52 AM | #7 |
The "Thing"
Drives: 2016 Camaro 2ss,Whipple,R888R,A8 Join Date: Sep 2016
How do thwy hold off the hit. I have a whipple and over 600 to the wheels. Im not sure if i should get a set of those for the strip or stay with the Toyo R888R. they are considered an autocross tire, they stick.
Helping Others
06-19-2018, 09:15 AM | #8 | |
At 20psi tire pressure I bogged off the line from a 3500rpm launch. I clutch kicked after the bog and it barely chirped the tires. They surprised the hell out of me. If I slip the clutch at 5500rpm it does great. They stick a little better than my mickey Thompson’s did in my opinion. |
06-19-2018, 09:18 AM | #9 |
The new nitto NT05R are the newer drag radial version. Friends 900whp c6 runs them and he says they hook.
06-19-2018, 04:15 PM | #10 |
Drives: 2018 2SS Convertible MBM/Kal Join Date: Feb 2018
Newb question here:
The rub issue is from putting the 305’s on the OEM SS rims and having an offset problem, correct? I’ve got a set of MRR FS01’s with 285/305 MPS4S’s on order. PK said they are direct application. Are there any rubbing issues with my set-up? Thanks for helping calm a newb who is setting up his first performance car in almost 20 years... (And first new car in 12.)
2018 2SS Vert. MBM/Kalahari. MRR FS01’s with 285/305 MPS4S. Black Bow ties, A8, MRC, NPP, 6-piston Brembo’s w/ matching rears, OEM Ground Effects/Splash Guards, 8”/Nav. Borla S-type, Pray IM/TB, RotoFab.
Past DD’s of note: 2013 Caprice PPV. (“Company” car.) 1998 Cadillac STS 1996 Impala SS 1969 Cadillac DeVille Convertible 1993 Corvette 1991 Mustang 5.0 LX 1973 Alfa Romeo Spider 1986 Mustang GT T-top 1964 Falcon Sprint Hardtop. (First car, still have the key!) |
06-19-2018, 04:28 PM | #11 |
if you are lowered and have a 305/35 or higher in the rear you will rub if you do a 305/30 you will be fine
06-19-2018, 05:45 PM | #12 |
Krops: Thanks for the info. My vert has MRC and is still bone stock. (Only 6 miles on it.). No plans to lower.
Just checked my invoice. I did order the 305/30/20’s for the rear. The car is at the dealership right now getting the last LPO’s done, (6-piston front Brembo’s and matching red rears, kalahari knee pads.) Hope to have it in the morning. New car, impatient owner!
06-19-2018, 06:35 PM | #13 | |
I don’t know about all tire brands but you can run 305/35 tire size. 5mm spacers are $30 and it did not scrub. On a side note NT555r radial does not come in a 305/30 Last edited by Slidewayz-Jones; 06-19-2018 at 06:37 PM. Reason: Added note |
06-19-2018, 11:04 PM | #14 |
Drives: '18 Zl1. '18 GT350. Join Date: Dec 2016
Stupid stupid questions, but what does that wiring harness control? I wonder if that is the cause of all my CEL's and Rear End/Rear Axle warnings coming on cus I do rub a bit on that side.
There's only 2 people I trust. 1 of them is me, the other's not you. 2018 Zl1. 1199 RWHP/931 TQ.
