dave@hennessey
Old 05-19-2024, 11:36 AM   #1
krest509
Drives: Rs 2011
2011 Camaro AC help please!!
Sup guys , I have been having all type of issue with my 2011 Chevy Camaro
Especially with the A/C so far , I took it to a shop he inspect check for online leak nothing , we added freon last for a few days then stop blowing cold.
Once I did notice a white air like smoke coming out of the AC vent before it stop working , that was only one time. ( one mechanic told me it could be a my evaporator Core could leak.) and to get through that my windshield window have to come out , and it’s labor intense .
With summer literally here living in south Florida I am cooked if I don’t do something lol.
Fr
This issue made inside of the car hotter then Ever
So today I got this message displaying
Not sure if it has anything to do with the AC system
You guys always give me great guidance
I hope for the same .
krest509 is offline   Reply With Quote
Old 05-19-2024, 12:49 PM   #2
redcoats1976
you need to check your cooling system and make sure its up to snuff.i believe the a/c will not function if coolant(radiator) temp goes over a certain level.id check radiator cap,temp on the DIC or even better use a temp gun to verify coolant temps when running before i did anything else. do you have a trusted local mechanic ?
redcoats1976 is offline   Reply With Quote
Old 05-19-2024, 01:54 PM   #3
krest509
Drives: Rs 2011
Thank you
And yes I do
Old 05-19-2024, 06:02 PM   #4
bsn
Drives: 2013 ZL1
If you saw what looked like white smoke coming out of the AC vent you most likely have a bad evaporator.
bsn is offline   Reply With Quote
Old 05-19-2024, 11:59 PM   #5
ariZona28
Give speed a chance
ariZona28's Avatar
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28
How long had you been driving for before you got the AC OFF message? Your temp gauge in your speedo cluster is below "C". That doesn't seem right for a high temp warning.
ariZona28 is offline   Reply With Quote
Old 05-20-2024, 02:42 AM   #6
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
I looked at the same thing, does the engine temperature sensor work at all ?
chevy pilot is offline   Reply With Quote
Old 05-30-2024, 10:05 AM   #7
krest509
Drives: Rs 2011
I’m not sure how long I was driving but
When ever that message come on .
The temp gauge does it, it it won’t go back to normal , I just put a new coolant Gauge in the car , it had none .
I’m just not sure what’s going on and it’s like 105 degrees outside I can’t survive this lol. They AC just doesn’t work
Old 05-30-2024, 10:06 AM   #8
krest509
Drives: Rs 2011
It doesn’t work , but when ever the ac temp message come up , it does that.
What you think ?
Old 05-30-2024, 10:07 AM   #9
krest509
Drives: Rs 2011
But will that cause me to get this message , and would that cause my temp gauge to fall below the C ?
