Old 05-17-2024, 06:50 PM   #1
Hetfield03
Hetfield03's Avatar
Drives: 2010 2LT/RS Black/IOM
Switchblade Key Fob Damaged by Repair Shop. Now what?
My air condenser was replaced by a repair shop that I have gone to on numerous occasions. The garage was nice enough to drive my car back to my house for me, and put my key fob in the mailbox like I asked them to.
But when I woke up this afternoon to get my keys out of the mailbox, they were gunked up with grease which I tried to wipe away, only to find that there was a big hole in the trunk button that I know wasn't there previously.
As you all probably remember there was a recall on these and I never went and got the new ones because I like to switch blade fob better.
So should I just say nothing or should I let them know about the damage, because chances are I'm just going to have to go to the dealership and get the replacement key fobs anyway.
ZL1 Factory Reproduction Wheels, Airaid CAI, MRT V 2.0 Axle Back Installed by PIE Customs, Painted IOM Rally Stripes, Bowties by Danny Taylor Louisville KY, IOM Engine Cover and Fusebox Cover by River City Creations and Lighting San Antonio TX.
Hetfield03 is offline   Reply With Quote
Old 05-17-2024, 07:54 PM   #2
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
It’s probably just old and cracked deteriorated away. Order one on Amazon and replace the guts with this one
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 05-17-2024, 08:15 PM   #3
Hetfield03
Hetfield03's Avatar
Do they all need a key cut by a locksmith, like this one?
Edit: YouTube has just about everything.
Looks like the original fobs are a p.i t.a. to get open however.
https://keyless-remotes.com/chevrole...kaAp8aEALw_wcB
Old 05-17-2024, 09:27 PM   #4
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Send a message via AIM to SSE 4 2SS Send a message via Yahoo to SSE 4 2SS
I have two of these but they are spoken for...
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
“If everything seems under control, you're just not going fast enough.” Mario Andretti
If you can turn, you ain't going fast enough...
SSE 4 2SS is offline   Reply With Quote
Old 05-18-2024, 06:35 AM   #5
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
There is just a little roll pin that holds the key on. You don't even have to get them cut. Just swap your existing key into the new fob.
FYI, in my experience the aftermarket fobs don't last as long as the factory ones, but that is just something you have to live with. I had a fob fail the same way yours did and another on the way out.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
CamaroCracka is offline   Reply With Quote
Old 05-18-2024, 08:47 AM   #6
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
That fob is wore out and is due for replacing anyway. That would have happened soon anyway so I wouldn't worry about it. When my fobs wore out, I replaced them with these https://www.ebay.com/itm/295814531489. And yes the factory fobs was such a pain to get open. I think I ended up taking a pair of needle nose pliers and breaking off the back because over the years the fobs got so full of gunk they wouldn't separate.
Mr_Draco is offline   Reply With Quote
Old 05-18-2024, 08:56 PM   #7
myold88
myold88's Avatar
Drives: SUMMIT WHITE 2SS/RS CAMARO
Look up: Batteries Plus Bulbs. There are several near me so see if you have one.
They stocked my '10 SS key fob plus the equipment to program it. I bought 2 since
I only had to pay for one set up. In stock, inexpensive and in and out of their store
in less than an hour.
myold88 is offline   Reply With Quote
Old 05-18-2024, 09:26 PM   #8
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
Doesn't the dealership still offer these switchblade fobs even if you decline the new ones they provide for the recall? That's what I did about 7 years ago. Unless these are discontinued as well??
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 05-18-2024, 10:04 PM   #9
CAMARO_HEAVEN
Big John
CAMARO_HEAVEN's Avatar
Drives: Wife 2013 Camaro 2SSRS / ME?
I bought these 2 years ago and paid the extra $20 to have them cut my keys. They did it from a high resolution picture and work perfectly. Both are still holding up great for a $40 investment. My car only came with one key and no fob and programming was simple.
https://www.ebay.com/itm/11444883802...mis&media=COPY
CAMARO_HEAVEN is offline   Reply With Quote
Old 05-19-2024, 07:53 AM   #10
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
They do but depending on your dealer, they are very expensive.
