Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 09-12-2020, 10:35 AM   #29
Scotty D
Drives: 2014 1le 1SS CRMT
Trailing arm outer bushings
Scotty D is offline   Reply With Quote
Old 09-12-2020, 10:37 AM   #30
Scotty D
Originally Posted by SIM GhostrdrZ View Post
Great job.
What a long process you’ve gone through. Hope you get it together in time to enjoy a few good weather days. Did you figure out your diff?
Thanks bud
They said my differential was in spec
So I will have to see when it’s all back together & new differential fluid in it
Old 09-12-2020, 11:07 AM   #31
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
Wait how many bushings are on the rear knuckle? I'm having trouble figuring it out.
Sent from my SM-T837V using Tapatalk
Firefighter is offline   Reply With Quote
Old 09-12-2020, 01:09 PM   #32
Scotty D
I believe just the one
But there are 3
The yellow one it the trailing arm
Old 09-12-2020, 01:24 PM   #33
Firefighter
But there are 3
So the yellow bushing is the one you can get and usually comes with trailing arms. The other two are not replaceable?
Old 09-12-2020, 02:23 PM   #34
Scotty D
The yollew one you can replace
Its called the outer bushing
You can buy the bushings
It dosnt come with trailing arm
They are 2 separate things
The trailing arm comes with the inner bushing inserted in it
If you go on BMR website you can see them
They are like $34 new
Old 09-12-2020, 02:33 PM   #35
Firefighter
I have a set of the AFE (Pfadt) arms waiting to be installed. I believe it came with the outer bushings. The other two are the ones I'm curious about. I think. Do they really wear?
Old 09-12-2020, 02:37 PM   #36
Firefighter
This is the set I've got.
https://afepower.com/afe-power-460-4...-rods#overview
Old 09-12-2020, 02:39 PM   #37
Scotty D
[QUOTE=Firefighter;10866820]This is the set I've got.
Sent from my SM-T837V using Tapatalk[/
Yeah bro you should be good then the other ones are not serviceable
Old 09-12-2020, 03:03 PM   #38
Firefighter
[QUOTE=Scotty D;10866821]
My bigger question then is does "not serviceable" mean non wearing?
Old 09-12-2020, 03:15 PM   #39
Scotty D
[QUOTE=Firefighter;10866836]
Honestly good question I think it means you cannot replace the parts
But I can tell you my old knuckles are very loose in those spots
Old 09-12-2020, 03:20 PM   #40
Firefighter
[QUOTE=Scotty D;10866841]
See that's what I'm concerned about.
Are they just sleeved bushings or is there some kind of hemi joint going on?
Old 09-12-2020, 03:29 PM   #41
Scotty D
[QUOTE=Firefighter;10866847]
You know what let me look if I have to I’ll cut it open
Old 09-12-2020, 03:36 PM   #42
Scotty D
From the looks of it . I don’t think there’s anything to worry about mine just must’ve been broken in
