03-08-2018, 10:30 AM | #1 |
Drives: 2015 Camaro SS Join Date: Sep 2011
Reducing 60' times
Manual car stuck at 1.9 to 2.2. Would like to get down to 1.7 or lower
Car traps 119 mph with average around 117 mph but I have only ran 12.1..On 1" lowering springs, Bmr trailing arm, toe rods, subframe bushings, dss driveshaft, axles and Nitto 18" 555r.....Car either bogs or spins.. is it a matter of just a better Tire or am I missing something? https://youtu.be/ggc29PSkvtI
2015 Camaro 2SS Cam/Heads/FBO 498/447 SAE |
03-08-2018, 11:45 AM | #2 | |
Just need to find what works for you.
03-08-2018, 04:46 PM | #3 | |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
555r IMHO more like a street tire..I use the 05R and seriously considerin goin with slicks once I can fund it..slicks are for sticks! lol
and what Bill said above...drive that B out the hole like ya stole it! and don't get crazy with the burn out...no need to over heat the tires and to long puts to much heat back into the clutch when we least want it... and psi..gotta let the air out...more than ya would think...good luck OP you prob seen this before but any way...
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
03-08-2018, 05:27 PM | #4 |
555r’s Put psi at 18ish. Do a good 2nt gear burn out tell you see smoke rolling a bit. Take your rpms way up to 4500-5000. Forget the Green light. Just practice slipping the clutch and feeding the gas enough to keep the rpms around 3500. Your using the built up energy in the engine for the 1sr 5 feet or so.
03-08-2018, 06:11 PM | #5 |
Drives: 2015 camaro 1le Join Date: Jun 2015
Frank your video didn't show up.
03-08-2018, 07:41 PM | #6 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Yeah those are street tire times. As was said find the sweet spot in launch rpm, tire pressures and amount of burn out. Nittos are finicky on burn out.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
03-08-2018, 08:22 PM | #7 |
you can either try updating your browser or click on the link to view on youtube...peace
03-09-2018, 10:54 AM | #8 |
Sounds like I need to get a dedicated track tire..Anyone run a bias ply with a radial front at the track and does it get sketchy at the top end? Would a MT street R radial be worth the money over the 555r I currently have ?
03-09-2018, 12:41 PM | #9 | |
GPI Sales Consultant
Something you should think about looking into is gears. A 3.91 take out rear differential form a 1LE is a nice option. Even better is a set of 4.10s from Motive. When you've got more mechanical advantage the launch is actually a little easier as it's easier to stay out of the bog as you don't have to slip the clutch quite so much before you can get it out and your right foot down. And then, you're gonna be in a MUCH better place when you cross the finish line - you'r probably banging it into 4th just before the traps now. Then you can think about a shorter tire to further increase your mechanical advantage when you're ready to upgrade from the 555Rs. Then she'll really be singing out the back.
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message! |
03-09-2018, 12:44 PM | #10 | |
This is what it takes for me to run a 1.9x 60' time on a pure street tire ($107 Chinese junk). 4.10's make this so much easier, I can leave with less RPM, get it hooked, and the let her eat. Once I have the cam in this year I'll probably add 1500rpm to the launch RPM for street tires. Once I get on a real tire I'll have to figure everything out all over again.
03-09-2018, 02:43 PM | #11 | |
03-09-2018, 02:49 PM | #12 |
Especially with a cam, I think that's a choice you wouldn't regret for a second.
03-14-2018, 04:35 PM | #13 |
Going to see what these will get my 60' down to, along with line lock for better control heating up the tires. Real soft compound.Feels like a gel pad
03-14-2018, 04:51 PM | #14 | |
nice tires! those should make a nice diff!..last sat went back to the track..best so far and again learn a f load...
13 psi at @5200...hope to make it back this sun with my buddy's slicks...see if I can get the wheel spin down just a touch...1.6 or maybe a 1.5? or maybe broken axles and a busted R/P...lol...just got a used Metco D/S safety loop from a fellow c5 peep...sure wish my LPW cover got here too...just want to bust 11's on the stock cam and then...it's game on baby! OP..you gonna do the rear gears? there is a 3.91 diff currently for sale...easy peasy! good luck! BTW - I also had dynoSteve raise my rev limiter...kept hittin it on early runs...got a little paranoid on this run....the updated tune rev's to the moon!
