03-27-2017, 07:30 PM | #1 |
Drives: 2015 Camaro SS Join Date: Sep 2011
Numbers back from head install
not what I expected. Before. SAE479/424 after SAE 490/449.Same dyno
The tq increase Im happy with but 11hp...
2015 Camaro 2SS Cam/Heads/FBO 498/447 SAE |
03-27-2017, 07:45 PM | #2 |
What are your supporting mods? I would be happy with 25 TQ too! Are these ported stockers or new CNC heads?
2010 CGM Camaro 2SS LS3 Swapped A6 - GPI LS3 SS1 .647/.638, (224/237, 112 +4, 7Ί overlap) on CamMotion 8620 core, BTR Platinum .660" Dual Spring kit w/titanium retainers, CHE bronze trunnion upgrade, stock heads milled @ .015, Melling HV 10296 oil pump, TSP 1-7/8" long tube headers (W/Catless Off-road Pipes), Corsa Xtreme 3" Catback, GPI Ported/Rod Mod Intake, Stage 2 Ported Throttle Body, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, 160Ί thermostat - Megan Racing adjustable coilovers (lowered 1.75"), MRR M017 10/11" wheels-Tuned by Ryan @ GPI
03-27-2017, 07:46 PM | #3 |
Track time before and after?
03-27-2017, 07:49 PM | #4 |
Cam, LT headers, Cai..ported stockers that were milled.20 and larger 1.60 exhaust valves...
03-27-2017, 07:52 PM | #5 |
I just got the car back together Friday and tuned today.
So no post track times
03-27-2017, 07:56 PM | #6 | |
I only picked up 30hp and 20tq with heads but I also gained 5mph in the 1/4. Be optimistic!
03-27-2017, 08:09 PM | #7 |
Feels lighter due to the tq increase and seems to pull through rpm range quicker...
03-27-2017, 08:12 PM | #8 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
Well with +25 torque gain, +11 horsepower doesn't seem too bad given horsepower is a product of torque But as BFASTNOTLAST stated, let those ET's speak brother, be optimistic
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
03-27-2017, 08:24 PM | #9 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
I gained 15/9 at the wheels. Take it to the track.
03-27-2017, 08:27 PM | #10 |
That's not a bad gain for stock ported heads. Good luck man and get some passes in before the decent air goes away.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85 Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE 10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake Best 1/8 6.80@105.75 Best MPH 134.82 |
03-27-2017, 08:35 PM | #11 |
It already has here in Florida mid 80's all week....lol
03-27-2017, 08:50 PM | #12 |
You know as well as I do that's still not bad compared to what we will be dealing with 2+ months from now.
4 months straight of 95+ degrees and >90% humidity...Yuck. Makes me nauseous just thinking about it. Almost as bad is not being able to keep your car clean and dry for more than 24 hours in a row in the summer.
03-27-2017, 08:58 PM | #13 |
What I like is useable data here. Baseline and end result.
03-27-2017, 09:00 PM | #14 |
Thread Tools | |
