03-08-2017, 06:48 PM | #1 |
Drives: 2015 Camaro SS Join Date: Sep 2011
Piston movement?
https://youtu.be/Ly1CkzGUzWA
Is this normal for stock Ls3 block 14k miles?
2015 Camaro 2SS Cam/Heads/FBO 498/447 SAE |
03-08-2017, 06:54 PM | #2 |
They all rock in the hole.
03-08-2017, 07:08 PM | #3 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
95K miles on mine When I swapped heads. My pistons be rockin.....
Pistons are designed that way where the top of the piston is smaller than the bottom because of heat expansion at running temps. |
03-08-2017, 07:47 PM | #4 | |
Drives: ZL1 Join Date: Oct 2012
03-08-2017, 08:24 PM | #5 |
Drives: cars Join Date: May 2011
03-09-2017, 05:41 AM | #6 |
03-09-2017, 07:08 AM | #7 |
Thanks guys just wanted to sure that much movement was normal....
03-09-2017, 07:50 AM | #8 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
Don't hurt to double check but don't allow yourself to get paranoid...then mistakes happen b'cuz your always doubting yourself...in other works don't go lookin for probs that don't exist...(14k mi motor with O probs before head/cam work will not suddenly develop piston rock..get it?)
not slammin ya but hope to save you some aggravation...this should be fun...peace out... BTW - get that sig in...helps ALOT!
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
03-09-2017, 02:39 PM | #9 |
[QUOTE=frankwjr;9603369]Don't hurt to double check but don't allow yourself to get paranoid...then mistakes happen b'cuz your always doubting yourself...in other works don't go lookin for probs that don't exist...(14k mi motor with O probs before head/cam work will not suddenly develop piston rock..get it?)
not slammin ya but hope to save you some aggravation...this should be fun...peace out... No worries....I'm a Plumber by trade not a mechanic...lol so I tend to be paranoid on things Im not familair with....
03-09-2017, 06:22 PM | #10 |
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
There of course are different types of rings/ pistons for different purposes and clearances also needed for more nitrous friendly ;versus Blown ;or just N/A, stroked, etc.... and different compression ratios all to take into account. Along with all the bolts being TTY torque to yield needing replacement with head removals along with the new head gasket that can also be for different purposes.... Good Luck
I run special short skirt pistons made by race tech just for being stroked so long ;they are different in ring lands / crown and skirt design and are forged with valve reliefs and 11;1 compression net with stock cc heads, (mine are ported), and my block was clearanced and my aftermarket oil pan windage tray. For my connecting rods and stroke and rotating assembly being balanced even better than GM internally balances the stock LS engine. True piston rock is more a problem with the piston at the bottom of its stroke with a longer stroke not at the top BTW and a reason specifically to have pistons designed for the purpose as the LS3 engine has the sleeves cast into it and the sleeves extend past the block joined to it and therefore have to clearanced just as in the con rods touching the cylinder wall also the bolts on the con rods have interference when stroked. Happy Motoring.
03-09-2017, 06:43 PM | #11 |
Drives: Camaro Justice Join Date: Jun 2007
So why are the heads off?
03-09-2017, 08:15 PM | #12 |
Having them Ported, milled and larger lighter Xceldyne exhaust valves.
03-09-2017, 08:59 PM | #13 |
03-09-2017, 09:10 PM | #14 |
