03-06-2017, 07:57 AM | #15 |
Drives: 2012 2SS/RS LS3 Join Date: Dec 2011
I am going through the pushrod measurements with my my johnson 2116LSR right now, and the numbers I am getting are much longer than I expected. On base circle of the intake it takes 17 turns on my Comp 7702-1 length checker giving me effectively 7.650 base pushrod length for zero lash. Add in .035 for preload and that puts me at 7.685 PR lenght when my pat g cam came with 7.4 reccommendations.
Going in a ERL Superdeck 6 M5 with PRC 255 heads milled down to 69cc and bare minimum resurfacing. Just curious if the Johnson seat height is that much lower for the recommendations to be that far off? |
03-06-2017, 09:58 AM | #16 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
What is the diff deck height for this block vs stock? Apparently ERL is stopping all car related biz...wow..
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
03-06-2017, 10:56 AM | #17 |
Stock is 9.24 ERL is 9.22
08-13-2019, 07:58 PM | #18 |
Drives: 2014 Camaro 2SS 1LE /2011 2LT Join Date: Sep 2015
Johnson LSR 2116
Bringing back this tread here regarding the install and preload of Johnson LSR 2116, just want to pick your brain on how you set up your 2116. We are having a hard time to get the PR length right. Also did you notice any excessive valve train noise?
