10-20-2009, 10:47 AM | #15 |
Drives: '69 SS Convertible Join Date: May 2009
IAT is what? Internal Air Temp? I'm assuming the Temp inside the box if that's what IAT means?
-2010 Camaro 2SS | M6 | VR w/White Stripes | 1 3/4" KOOKS - 3" Magnaflow | LPE 3.91 gears | ADM tuned | Halltech w/ADM Scoop | Spohn/BMR Trailing Arm/Toe Rod | BC Coilovers| Pedders FE4 ZL1 swaybars | Cradle/Diff/Radius Rod bushings | VMax TB | Morimoto Projectors | MGW shifter | Red Calipers
Build Journal |
10-20-2009, 10:50 AM | #16 |
Looks like CAI may be the overall winner for most HP/TQ without tune and excellent fit. To bad their site isn't working well right now. If I remember correctly this is one that had heat shielding on the inside of the box. I think he also said it should be around the $400 range (can't remember).
I would like to see more info and pics for their CAI but their site is not really working and it's probably going to get kinda hammered over the next few days.
Build Journal |
10-20-2009, 10:50 AM | #17 | |
Beleive me it is minor and will not happen on every car on those that experience it Custom tuning definately helps a bunch. Some times you have to make Small sacrafices for Power. Gram/Cyl, is the Air flow reported by the MAF with ultimately controls fueling and selection of timing cell on the timing map. If you look you will see different timing recorded for each kit due to differences in Grams/Cyl reorted by MAF.
www.jannettyracing.com
10-20-2009, 10:50 AM | #18 |
Born again Hot Rodder
Drives: Black 1SS/RS LS3 M6 Join Date: Sep 2009
We're sorry.
This spreadsheet is not published. Find out more at the Google Docs Help Center. |
10-20-2009, 10:52 AM | #19 |
Updated.
10-20-2009, 10:55 AM | #20 | |
Dances With Mustangs
Blue Angel is here!! 1SS/RS LS3 M6 IBM |
10-20-2009, 10:55 AM | #21 |
SoCal C5 Family Member
Drives: 2SS/RS IBM M6-when she lets me Join Date: Oct 2009
Hey Uncle Ted I can't thank you enough for doing this for all of us! Great spreadsheet
i would like to know if you can tell me: Why is the "fuel trim" different? How does it get changed? If the fuel trim was "turned up" on the CAI, would it make more horsepower? And the IAT reading: what are "Good Numbers" compared to stock? Should they be higher,lower, or unchanged? Thanks Again and Have A Great Day! |
10-20-2009, 10:56 AM | #22 |
10-20-2009, 10:57 AM | #23 |
NOICE!!!
Great Job Jannetty racing thanks for the comparison
10-20-2009, 10:57 AM | #24 |
Their site started working for me as well but when I did a search on products I only found the filter replacements.
How much did you have to pay for the CAI? I'm going to try their site again in a few min.
Build Journal |
10-20-2009, 11:01 AM | #25 |
Okie doke
Untuned, I think it shows how efficient the stock system is .. Look at the timing on the stock runs
10-20-2009, 11:01 AM | #26 |
It's listed at $399. Mine was $418 with shipping.
10-20-2009, 11:06 AM | #27 |
Whipped
great job guys!
10-20-2009, 11:13 AM | #28 |
Drives: 07' TAHOE LTZ Join Date: Aug 2009
Can someone post a link to CIA. Thanks!!!
Thread Tools | |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Hot air Intakes -By Kenne bell | ADM PERFORMANCE | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 66 | 02-08-2011 08:33 PM |
aFe Stage 2 Cold Air Intake NOW SHIPPING from ECSpeedSound! | AJ@ECSMotorsports | V8 Bolt-Ons & Tunes | 44 | 11-13-2010 03:45 PM |
List of Intakes that will work with the TVS-2300 MagnaCharger | JJ2010 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 26 | 03-19-2010 02:11 AM |
Pedders Suspension Benchmark Track Testing and New Jersey Track Day | Info@PeddersUSA.com | USA - NY / NJ / PA | 35 | 10-26-2009 05:20 PM |
Cold Air Intake | xsofa | 4th Generation Camaros | 2 | 08-13-2009 05:40 AM |
