06-30-2020, 05:22 AM | #155 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
Yes it can. This is actually what most of us are doing (including myself!).
06-30-2020, 05:49 AM | #156 |
Drives: 2017 1SS Hyper Blue Join Date: Apr 2017
Thank you!
06-30-2020, 05:56 AM | #157 |
Yes, I have had one since Christmas and love it! Night and day difference my friend
07-03-2020, 08:21 PM | #158 |
Ordered one today!
07-06-2020, 08:04 PM | #159 |
Wow, fast shipping! I ordered on Friday and received today. Very classy packaging, too. Install was easy ( other than folding my creaky old self under the dash). I put the control on the little vertical area in the gap under the steering column. You don’t really notice it unless you are looking for it. Initial impression is that it works as advertised, response is way snappier than stock, and I like the many adjustment levels. Great product, good job Soler Performance!
07-06-2020, 08:17 PM | #160 |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
I'm curious how many of you that have both the Soler TB and TC feel it's a bit to much in terms of responsiveness. I just installed their TB, and to be honest it feels about perfect to me. Any more would almost be to snappy and responsive I feel. I had the Pedal Commander throttle controller on my Mustang, and with like 30 settings you could make it super responsive. But it just didn't feel right, because these throttle controllers don't actually the change the built in delays or dead spots, they just amplify the signal
07-07-2020, 04:45 PM | #161 |
I recently installed the throttle body and controller. I've been driving with the controller in OEM while allowing the ECM to relearn, but today I decided to play around with it since I've put on enough miles.
I tried a few different settings. The SP.X settings are too much. They're way too hot and make it really hard to drive the car smoothly. I like the CF.X settings much more, and even then I think a setting below CF.5 will likely be the final one I go with. Still a much better product overall than the Vitesse for less money. Last edited by BigGuy81; 07-08-2020 at 10:31 PM. |
07-11-2020, 10:28 AM | #162 |
Drives: 2019 SS/1LE Riverside Blue, Z/28s Join Date: Aug 2019
07-11-2020, 10:48 AM | #163 |
Makis
I don't need to see it. I set it at P2.5, I hid it in that little cavity under the steering wheel and I am never gonna touch it again unless I have to change the setting.
07-25-2020, 06:36 PM | #164 |
Drives: 2017 Camaro SS, 2017 2500HD, 2014 H Join Date: Jun 2020
Installed the controller today and put the control box in the console. The wire is just long enough!
I settled on SP.6 for now, although I played around with the LU settings also. Installation was easy, or at least as easy as working on these cars ever is! LOL! |
11-14-2020, 03:55 PM | #165 |
Drives: 2019 Satin Steel 1SS 1LE w/ PDR Join Date: Sep 2017
I grabbed one of these from a member on the forum and I finally got around to installing today. I just went for a quick test drive but I'm loving it so far!
I'm curious, if I unplug the display/"controller" and leave everything else plugged in, what will happen? I'd like to be able to unplug the display and hide the wires if I ever needed to bring my car into the dealership. |
11-14-2020, 05:55 PM | #166 | |
Contact Soler, maybe they make a shunt plug you can plug the controller end into and hide it away under the dash. Although on second thought, the plug at the pedal will still be there and will be a giveaway that something isn’t stock. Might be just as easy to unplug the Soler wire at the pedal when you need to take it in. |
12-09-2020, 06:01 PM | #167 |
Drives: 2015 Corvette Stingray Join Date: May 2019
Thanks, everyone. Here's a picture of our latest parts with darker etching.
12-10-2020, 05:35 AM | #168 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
They look even better in person.
It’s going to be a long few months before I can try them out. |
