04-02-2019, 01:23 AM | #1 |
Drives: 2015 Camaro SS 2SS Green Flash Join Date: Nov 2015
Custom C7 Z06 vented 6 Piston Upgrade
I am selling my Camaro and will begin de-modifying it this week in order to sale or trade it in.
The system contains the following items and you will only need to re-use your current rear rotors to make this a complete kit. This set-up cost over $2400. It has less than 500 miles on this system and is as new. $1750+Shipping GM 2015-19 Chevy Corvette Z06 Front Brembo 6 Piston Calipers $800 2010-2015 Camaro SS Brembo 4 Piston Brake Rear Calipers $400 GM OEM Front 2 Piece Rotor Pair Brembo $600 TPH Coatings Cyber Gray Metallic -$425 Ceramic Brake Pads-100% pad life remaining F/R Goodridge steel lines $160 I am located in Southern California and prefer a local pick-up but will ship |
04-02-2019, 09:46 AM | #2 |
Drives: 2012 SC'd SS Join Date: Mar 2018
So tempting...what backing plate is needed for the front? ZL1 backing plates?
04-02-2019, 01:50 PM | #3 |
You can trim the 4 piston caliper shield.
Orange Krush II
04-02-2019, 01:58 PM | #4 |
04-02-2019, 04:50 PM | #5 |
This is one modification that surely gets a lot of attention on top of the increased braking power
04-02-2019, 05:30 PM | #6 |
Do you have any pictures installed?
Any estimate on what the shipping will cost going to the east coast? |
04-02-2019, 11:49 PM | #7 |
04-03-2019, 07:41 PM | #8 |
04-09-2019, 07:09 AM | #9 |
Drives: 2016 Camaro SS Join Date: Mar 2018
Pm sent
Sent from my SM-G955U using Tapatalk
2016 Black M6 2SS - NPP, MRC
MRR M017 1LE Replicas, Rotofab CAI ARH 1 7/8 LTs w/ cats Pray ported MSD Atomic AirForce Intake Manifold + TB BMR upper/lower trailing arms and upper control arms Pray Tuned + E85 (490WHP) |
