01-21-2020, 02:55 PM | #1 |
Drives: 2016 Camaro 2SS Join Date: Oct 2016
Question about Costly Repair
Hey all!
I daily drive a 2016 Camaro 2SS that has just over 62,000 miles. Recently I have noticed that engine oil is leaking in my driveway. After taking the car to a Chevy dealership, they let me know that the oil pan gasket is leaking. They said that while the gasket is cheap, the labor cost for repair would be just under $2,000. Is this a fair price? I was told the engine would have to be removed from the car to access the repair. My first thought was to use ATP AT-205 Reseal, but according to my service guy the oil pan gasket isn't rubber but instead a type of silicone liquid of types. Is this true? Thanks in advance to any help! |
01-21-2020, 03:06 PM | #2 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
That is completely out of line. You can unbolt the motor mounts, lower the cradle and raise the motor enough to get the pan off. I'm pretty sure a competent mechanic could replace the pan in a fairly leisurely 8 - 10 hours.
Baby Blue
01-21-2020, 03:50 PM | #3 |
Drives: 2017 2SS / 2003 S10 Crew Cab Join Date: Oct 2019
It would be worth your time to get another opinion either at another dealership or independent shop. Gasket technology is much better now; they usually don't just fail on their own without an underlying cause.
Never say never! |
01-21-2020, 03:59 PM | #4 |
Drives: 2021 Camaro SS 1LE Join Date: May 2009
YIKES.......they are way overcharging you.......
2021 Camaro 1SS 1LE - Red Hot
2015 Camaro Z/28 - Red Hot 2001 Mecham Trans Am #3 - 7.0L LS1 |
01-21-2020, 04:09 PM | #5 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
Repairpal.com says labor should be around $415.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
01-21-2020, 04:58 PM | #6 |
Drives: A few Join Date: Oct 2017
Not if it's an 8-10 hour job as another poster said.
I never bothered to look to see how much would it would be to replace the pan on one of these though so not sure if that 8-10 hours is accurate.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback Too many cars.. never. |
01-21-2020, 05:03 PM | #7 | |
Forgive my ignorance, but what kind of underlying issue would cause the oil pan gasket to leak? The service rep at the dealership had the attitude that this was a fairly common thing to have happen over time. Thanks again! |
01-21-2020, 07:05 PM | #8 | |
Never say never! |
01-21-2020, 08:14 PM | #9 |
there is no gasket. they use gasket maker RTV. if it is the oil pan its leaked because the bolts were improperly torqued or sealer was improperly applied or a defective oil pan. All are manufacturers defect . 2 thousand miles over warranty. a good dealer would take care of it.
01-21-2020, 08:51 PM | #10 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
First thing I would do is get under the car use brake cleaner and get all the oil residue cleaned up. Then I would drive the car for a week and get back under and trace it down. I would not trust the dealer if they didn't take the time to clean it up, could be anything and might be a simple fix. Find it hard to believe the pan is leaking at 60k miles. I have a 2016 LGX and not a drop, 2006 GP with 130k not a drop. then again my 2005 2500HD does have a leak but its not worth doing the rear seal (major pain).
01-21-2020, 10:12 PM | #11 |
Who Needs to KNOW?
May be RMS and not pan gasket.
Start w good degreaser / power wash and once dry, corn starch the problem area - oil clings to corn starch and leaves you a nice, easy to follow trail.
ing for grip.
01-21-2020, 11:49 PM | #12 |
Drives: 2018 Camaro SS 1LE Join Date: Oct 2018
I believe there was a TSB on this. There was an issue with the factory bolts not properly tightened down. Either way, looks like its about a 400-500 job. Your dealership is trying to take advantage of you becuase either they are greedy, or Incompetent. Either way, take it elsewhere...
01-22-2020, 07:26 AM | #13 |
Drives: Former 2016 Camaro 1LT Join Date: Jan 2017
Dealerships will always charge the most for any repair. As already stated, best to find a good shop with good reviews and get them to do the work.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
01-22-2020, 08:23 AM | #14 | |
-Dave
