Old 07-21-2018, 01:09 PM   #15
Badgerbimmer
Badgerbimmer's Avatar
Drives: ZL1 A10
saw the 44 offset on the 11s, couldn't see the # on the 10.5s
My rides:
2017 Camaro ZL1 A10
2015 Jeep Grand Cherokee Diesel
2012 Audi S4
1992 Porsche America Roadster
1990 BMW 325Ic
Badgerbimmer is offline   Reply With Quote
Old 07-21-2018, 06:27 PM   #16
NickyRacerBoy
Drives: 1LE
27
NickyRacerBoy is offline   Reply With Quote
Old 07-21-2018, 06:35 PM   #17
NickyRacerBoy
Drives: 1LE
https://www.apexraceparts.com/wheels...c-7-wheel.html
Old 07-21-2018, 07:15 PM   #18
NickyRacerBoy
Drives: 1LE
Badgerbimmer
If I were to go with a custom Penske's shocks, from Phoenix Racing, then 11" NP in the front.
Old 07-22-2018, 06:32 AM   #19
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Originally Posted by NickyRacerBoy View Post
I believe 3/4 spacer. I will measure and verify. Also removed material from strut as found another thread. Let me see if I can find that thread. I will take pics either way when at the track on Monday.
NJMP's calendar shows a private track event tomorrow. That you?
I'd like to see that beast of yours.
Norm
Old 07-22-2018, 09:25 AM   #20
NickyRacerBoy
Drives: 1LE
Norm
Yo Norm,
Yeah thunderbolt tomorrow... Keep fingers crossed that rain holds off. I'll be I. The garage.. Come see me.
Old 07-22-2018, 11:47 AM   #21
hzycamaro
hzycamaro's Avatar
I didn't know 18' wheels will fit SS. Do you have to use spacer?
hzycamaro is offline   Reply With Quote
Old 07-22-2018, 01:15 PM   #22
NickyRacerBoy
Drives: 1LE
Yup... 3/4 but let me verify.. Front only btw
Old 07-23-2018, 08:00 AM   #23
Badgerbimmer
Drives: ZL1 A10
I used one of the wheel calculators and input the stock wheel numbers for the 10" wheel to calculate what the dimensions would be on an 11" wheel to get the proper inside spacing. The numbers come out 20 x 11 ET 7. (not sure if this small of an offset would cause a problem clearing the caliper). I would prefer not to grind the strut or use spacers. I have the Moreno camber plates and achieved -3 with the plates at full negative then adjusted at the knuckle to get to -3. This approach does not add enough room for a bigger wheel.
Apex said they were going to start making wheels that fit. Haven't seen anything come out as of this time.
My rides:
2017 Camaro ZL1 A10
2012 Audi S4
1990 BMW 325Ic
Old 07-23-2018, 09:28 AM   #24
RXtacy
RXtacy's Avatar
Drives: 93 RX-7, 17 SS 1LE, 04 RX-8
That number sounds right. I run 18x10.5 +22 with a 12mm spacer so +10 effectively. This is on an SS 1LE with max knuckle camber (-2.5). With a 20" diameter though I believe you will have more clearance. The tight spot is at the strut tab and as you go higher (larger diameter) the clearance increases.
RXtacy is offline   Reply With Quote
Old 07-23-2018, 09:30 AM   #25
RXtacy
RXtacy's Avatar
Originally Posted by JDP Sales View Post
Good stuff!! Be careful what tires you run. Those tires look an awful lot like the tires we were running when the wet sump wasn't able to keep oil in the engine of our 2016 Camaro SS on the road course. We lost the engine as a result.
All the best,
Jared
Can you give us more details of this incident? What kind of turn, speed, lateral g's etc. Many of us are running sticky tires on track and monitoring oil pressure without issue so far. This is the first I've heard of an actual oiling issue on this platform so would love to know more.
Old 07-23-2018, 09:31 AM   #26
RXtacy
RXtacy's Avatar
Well I'm ready to go back to the track this Monday hopefully I have more front end grip
Nice setup. Was just at Lightning on Thursday. Interested in how the sidewalls feel with such wide tires hopefully they won't be "vague/squishy".
Old 07-23-2018, 06:45 PM   #27
NickyRacerBoy
Drives: 1LE
Norm
Hey Norma was nice meeting you today
Old 07-23-2018, 06:49 PM   #28
NickyRacerBoy
Drives: 1LE
So spacer is 3/4. Apexi rim in my previous post will fit without strut mod when running 295/30/18 but it you wanna squeeze 315 then strut needs modifications
