01-18-2017, 05:57 AM | #1 |
Drives: 2015 Ls black Join Date: Aug 2015
2LS Differential question
Hey I own a 2015 2LS with the 2.92 carrier and gears and i was wondering if i could just buy and install an LT 3.27 open carrier and install it in without needing any other parts or will i still need to buy hubs etc...
Thanks Mike |
01-18-2017, 10:31 AM | #2 |
Drives: 2013 Camaro 1LT Join Date: Jun 2015
I'll have a 3.27 diff, axles, and hubs available at a real good price in a few weeks...
Elite catch can & clean side oil separator, Apex Scoop, CAI cold air intake, Vmax ported throttle body, TTT ported intake manifold, JacFab intake manifold spacer, Magnaflow cat back exhaust, Weld RT-S 17x5 f and 17x 9 r wheels, MT 28/6/17 f and M&H 275/50/17 r tires, TTT rear seat delete, Nitrous Outlet plate kit, 125hp jets.
01-18-2017, 10:31 AM | #3 |
01-18-2017, 10:33 AM | #4 |
Yes.
01-18-2017, 10:36 AM | #5 |
01-18-2017, 10:48 AM | #6 |
My SS stuff is getting shipped out today. I'll get it Friday. Then I'm on vacation until Feb. 1st. When I get back I'll do the swap, hopefully it won't take long. Only 21k miles on it and has had the fluids changed every 10k. Probably let the whole shooting match go for $400.
01-18-2017, 10:51 AM | #7 |
I would only need the diff if your willing to separate
01-18-2017, 11:32 AM | #8 |
Yeah we can work something out. You're not in a hurry are you?
01-18-2017, 12:02 PM | #9 |
In the next couple weeks time
01-18-2017, 12:25 PM | #10 |
Ok. It's probably going to be around 2/10 before I have it out.
01-18-2017, 12:34 PM | #11 |
Ok keep in touch
01-19-2017, 02:36 PM | #12 |
Drives: 2015 Camaro LFX A6 Join Date: Nov 2015
Is someone able to confirm this is a direct swap without any modifications or additional parts... literally just pull the 2LS diff and swap in an auto LT diff?
I also have a 2015 2LS and am trying to figure out my best option for upgrading my rear end in terms of performance. Considering the Richmond ring and pinion swap which Im told just drops into the existing 2LS diff with no modification whatsoever.
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
01-19-2017, 04:18 PM | #13 | |
Drives: 2013 1LT RS Camaro Join Date: Apr 2016
The Richmond 3.55 Ring and Pinion set does fit the the 2LS carrier and your current axles and hubs would remain the same. There is more to swapping out the ring and pinion set than just un bolting the old one and bolting in the new one. There are one time use bolts, end play and gear engagement issues. If you haven't done this before and are unfamiliar with the process, it's best to have a professional do the job. As setting it up with the wrong engagement or backlash can ruin the gear set. Check around it should be around 300 dollars. Going from the 2.92 to the 3.27 gear will improve your acceleration, but going to the 3.55would give you a much more dramatic change. The old school rule of thumb, just for guesstimation purposes is for every .1 you increase your rearend gear ratio, you will approximately lower your 1/4 mile et. by .1. I believe the factory stated time for the 2LS is 14.8 and the auto LT is 14.4 and the difference in the rearend ratios is .35. So going to the 3.55 should put you around 14. Seconds or so. Like I said this is all just an estimation, as lots of variables are entailed in a 1/4 mile run/time. Hope this helps you. Last edited by Kenny Camaro; 01-19-2017 at 04:31 PM. |
01-19-2017, 07:25 PM | #14 |
Drives: 2022 Cheverolet Camaro RS V6 Join Date: Nov 2016
Would it be as easy with a 3.27 going to 3.55? Just a ring and pinion swap?
Tx12Camaro
2022 Camaro V6 1LT RS |
