03-04-2016, 11:14 PM | #1 | |
Drives: 2015 Ls black Join Date: Aug 2015
installed ported throttle body heres a cold start
The car idles down at around 35 sec mark
03-04-2016, 11:57 PM | #2 |
Drives: 2015 Black 2LT RS M6 Join Date: Aug 2015
What exhaust are you running?
Overkill tune/E85/80mm•CAI cold air intake w/my custom maf tube•Apex air scoop•JacFab ported intake/Extendolater•Vitesse•EE EX2 catch can•Innovate wideband•ARH HFC's•NPP exhaust•11386 xpipe•Brembos/cross drilled/slotted rotors•SS M/C•Pfadt 1.25 springs•1LE struts/sways/strut tower brace•BMR diff bush, trail arms/bush, adj toe links•My custom Tunnel brace•Hurst short throw shifter•JDP stage 1 clutch res•1LE steering wheel, shift boot•ZL1 rear diffuser/splash guards•GM splitter•Z/28 grille/flowtie/spoiler/wheels•GM performance pedals•"Chevrolet" door sills•10" Kicker sub•BigWorm overlays
03-05-2016, 12:04 AM | #3 |
Mrt v1, resonator delete, true x-pipe 2.5 inch piping
03-05-2016, 04:52 AM | #4 |
Drives: 2013 Camaro 2LS Join Date: Feb 2013
Sounds nice !
Can you take a video with some revs, and do a drive by ? |
03-05-2016, 04:53 AM | #5 |
I will soon.
03-05-2016, 01:46 PM | #6 |
Drives: 2013 Camaro Join Date: Feb 2016
Which tb you got installed?
Elmayimbe |
03-05-2016, 02:01 PM | #7 |
VMax ported
03-09-2016, 07:28 PM | #8 |
Drives: 2013 Blue Ray Camaro Join Date: Jun 2014
Yeah that's sounds good. I might go with your exhaust setup. I've been on the fence on what to get forever.
Sent from my SM-N920T using Tapatalk |
03-09-2016, 09:42 PM | #9 |
The VmAx did what for your car? Improved sound ? Acceleration ? I'm Curious because I want to get one for my car. Thanks
Elmayimbe |
03-22-2016, 10:15 PM | #10 |
the Vmax gave me a night and day throttle response and it has been proven to get you very slight increase in hp and tq like 1-2hp/tq gains and a slight better mpg as for sound it gave my set up a deeper tone and way better idle sound @cubamvp
03-23-2016, 12:58 AM | #11 |
About how long does it take to install the tb?
03-23-2016, 01:01 AM | #12 |
30 mins max and that's moving slow its 4 bolts and a plastic wired connection and loosing the clamps on your intake tubing. That is all.
03-23-2016, 01:12 AM | #13 |
Cool thanks, I just wanted to know because I want to get one and I would only have about an hour and a half to install it.
03-23-2016, 10:23 AM | #14 |
Drives: 2013 Camaro 2lt RS Join Date: Apr 2015
So the tb gave it better sound? By the way thanks for the reply.
