11-14-2016, 05:28 PM | #365 |
Drives: 2013 Camaro 1LS - Ashen Gray Join Date: Jan 2015
Yes blow thru
"WIDOW" Overkill Edition w/Mace Cams,80mm tb,Jacfab spacer/ported intake,Alky Control,ARH off road pipes,SOLO custom system,3.91 gears, MGW,Phantom grilles,ZL1 appearance pkge, 3dCarbon vents, Lingenfelter hood and spoiler, PLX boost/wideband modules/gauge,ZL1 fuel pump,LF3 hpfp,DSS aluminum driveshaft,JPSS sway bars, Z28 replica wheels and CxRacing coilovers..
11-14-2016, 05:32 PM | #366 |
Drives: 2015 Black 2LT RS M6 Join Date: Aug 2015
Overkill tune/E85/80mm•CAI cold air intake w/my custom maf tube•Apex air scoop•JacFab ported intake/Extendolater•Vitesse•EE EX2 catch can•Innovate wideband•ARH HFC's•NPP exhaust•11386 xpipe•Brembos/cross drilled/slotted rotors•SS M/C•Pfadt 1.25 springs•1LE struts/sways/strut tower brace•BMR diff bush, trail arms/bush, adj toe links•My custom Tunnel brace•Hurst short throw shifter•JDP stage 1 clutch res•1LE steering wheel, shift boot•ZL1 rear diffuser/splash guards•GM splitter•Z/28 grille/flowtie/spoiler/wheels•GM performance pedals•"Chevrolet" door sills•10" Kicker sub•BigWorm overlays
11-14-2016, 07:58 PM | #367 |
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
I have a spare SC side mounting plate , just make me an offer
2017 Grand Sport, Borla X Pipe.....Enough Said
11-15-2016, 05:41 PM | #368 |
Drives: ZTS pearl in autoflex Join Date: Sep 2013
Where did you get that maf housing from?
Full MBRP 3in exhaust, Vitesse TC, BBK LT, black iceolator, VMAX TB, vararam, LG coils, zl1 reps, zl1 front bumper, zl1 grille, zl1 rockers, CF Copo hood, CF trunk, gm blade wing, HAVOC diffuser, APR splitter, dipped SS calipers
11-15-2016, 06:20 PM | #369 |
It comes with the used kit I'm buying
01-12-2017, 11:54 PM | #370 |
Drives: Supercharged LLT Join Date: Aug 2012
Does anybody know what belt part number if using the Standard LLT pulley for the gatorback or continental belts ?
01-13-2017, 01:00 PM | #371 | |
its on page one of this thread, i haven't been able to find a gator back that works and the continental i had was just barely too loose
01-13-2017, 07:46 PM | #372 | |
[COTW 4/13/15]
Drives: Supercharged LLT Join Date: Jul 2010
Gates- K061066 (6PK2708)
01-13-2017, 08:08 PM | #373 |
Nice
01-13-2017, 08:22 PM | #374 | |
http://m.ebay.com/itm/141504167693?_...68&_mwBanner=1 |
01-13-2017, 11:15 PM | #375 | |
01-14-2017, 04:55 AM | #376 |
So which belt would you or anybody that has swapped out belt suggestion?
01-14-2017, 07:36 AM | #377 | |
Edit, NVM just looked at your build thread and see most of this is already done. I don't think you clean side should be under vac though (just filter vent to atmosphere)
01-14-2017, 08:08 AM | #378 |
Thanks for the advice
