dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Forced Induction - V6
Old 03-09-2015, 05:18 PM   #169
JantzenOKC
JantzenOKC's Avatar
Drives: '13 2LT/RS Twin Turbo
Another victim of the RX catch can...
I can't wait to get mine off the car. I pushed my car to 7200rpm in 3rd gear once yesterday at the track so I wouldn't have to shift into 4th gear before the traps and I had what i thought was a huge vacuum leak. Turned out the rx catch can just freaked out and was making the loud sucking air sound. I turned the car off and let it sit for a minute then restarted and it was gone. Glad your issues are gone.
JantzenOKC is offline   Reply With Quote
Old 03-12-2015, 05:28 PM   #170
13blackLS
13blackLS's Avatar
Drives: 2013 camaro ls; 2005 rx8
I got everything installed, but now the idle is off...car is a '13 automatic...was idling right around 500 prior to install...its now idling at 500 and bouncing up to 750...its going back and forth few seconds on each rpm....anything i should check??
Second thing is the tensioner pulley is on the right tick mark when running, is that where it should be?
And last, there is a loud squeaking (sounds like a pulley) i dont see anything rubbing, is there a way to grease or lube the pulleys? Or what else should i be checking?
Any help would be appreciated, thanks in advance!
13blackLS is offline   Reply With Quote
Old 03-12-2015, 07:28 PM   #171
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
Did you flash the IPF tune yet ? The idle bounce is usually fixed with the tune.
There should be no need to lube the idler wheels. Loosen the belt and spin the idlers, they should spin easily with no binding or the feeling like there is sand in them.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 03-12-2015, 07:39 PM   #172
Pathogen
Pathogen's Avatar
Drives: 2014 1LS Camaro
Also, you may have a vacuum leak. I had an issue with the two bolts that hold the steering reservoir bracket being too long and they dug into the lower pulley.
Nobody with a good car needs to be justified. -Flannery O'Connor
Pathogen is offline   Reply With Quote
Old 03-12-2015, 08:01 PM   #173
13blackLS
13blackLS's Avatar
Yeah, flashed the tune...its not as bad when i put it in drive...i will check the bolts and pulleys also, they spun freely...i will try and see if i can pinpoint the squeal...it sometimes disappears and comes back lol
Old 03-13-2015, 06:28 AM   #174
sycraft
COTW 5/06/2013
sycraft's Avatar
Drives: 2017 Corvette Grand Sport-Ho-Vette
pull the oil cap off when running, if the squeak goes away you have a evap/ vacuum problem....
2017 Grand Sport, Borla X Pipe.....Enough Said
sycraft is offline   Reply With Quote
Old 03-13-2015, 08:09 PM   #175
13blackLS
13blackLS's Avatar
Ok, i removed oil fill/breather (from mm) and squeak didnt go away (pretty sure its a pulley) ill remove and check...
Also checked all pcv fittings and everything was good and tight
Ipf said the correct tune was picked and loaded...i checked and rechecked maf connection and even installed a brand new maf sensor (as ipf said idle may be maf related) and its still fluctuating rpms...
Could it be a leak in the charge pipes causing it? I replaced all the clamps and tightened them as much as i could...
Boost gauge showed vacuum bouncing between 10 and 20 as the rpms bounced...
Im about to give up lol
Old 03-13-2015, 08:33 PM   #176
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Tensioner should be in the middle.
Idle is supposed to be at 800 RPM's (at least on the LLT, that is what the tune is set to). Make sure your brake booster line isn't leaking.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 03-13-2015, 09:52 PM   #177
13blackLS
13blackLS's Avatar
Ok, i will pick up a new belt tomorrow to adjust that...
Checked brake booster lines and everything seemed good...
I will contact ipf again and see if they have anything else for me...thanks again guys!!
Old 03-13-2015, 10:05 PM   #178
MagnumForceGB
Do you hear any clicking noises from the engine bay when the key is in the run position but the engine is off?
Old 03-13-2015, 11:34 PM   #179
13blackLS
13blackLS's Avatar
Nope, no noises that i can remember...i will check again in the morning to be sure
Old 03-13-2015, 11:37 PM   #180
Lombardi
Lombardi's Avatar
Drives: 2010 ABM Camaro 1LT
I had a bad squeak on mine. new tensioner and all better. my old tensioner wasn't bad just work the new belt and system wasn't holding it tight enough
Lombardi is offline   Reply With Quote
Old 03-14-2015, 10:13 AM   #181
MagnumForceGB
Ok, that was to make sure the throttle body was good.
Is the recirculation valve hooked up right? If that valve is closed it is forced to get air through the supercharger and can cause idle problems.
Old 03-14-2015, 01:45 PM   #182
13blackLS
13blackLS's Avatar
No clicking with key on and engine off...
I will check the recirculation valve again!!
Also got a new belt i will throw on aswell
Thanks so much for helping me troubleshoot!!
