dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 05-29-2011, 10:40 AM   #29
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
I just read this whole thread and thanks camaro 1 for clearing up the total confusion, it was funny how everyone could not comprehend what you were describing. and as far as the idea of not fooling with this for 100,000 mi. does not compute for me at all. I will not wait that long to service my trans, plus what if someone puts a trans cooler or swaps out the radiator for a heavyduty be-cool radiator, and has to undo the trans lines and loses fluid like I'm about to do. I do apreciate the op for trying to share but if they dont know what there doing they should not write a diy post. thanks again to camaro 1, great write up.
2010 Hennessey HPE650 2SSRS Blk/Blk
Magnuson TVS2300,ported heads,cam,Hotchkis suspension. Weld 17”s, Mickey Thompson’s.
klatterblast is offline   Reply With Quote
Old 05-29-2011, 11:31 AM   #30
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
I am going to get one of these kits so I can fill/check the trans fluid.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 06-22-2012, 07:18 AM   #31
mgoodbar
White 2ss, LT, CAI, Tune
Drives: 2010 L99
whats the torque speck on the pan bolts???
mgoodbar is offline   Reply With Quote
Old 06-22-2012, 09:14 AM   #32
MRGOODWRENCH3
Drives: 2010 Camaro 2SS/RS
If you are going to take the time to change the fluid why not just drop the pan, get all the fluid out, clean the pan and magnet and change the filter. I upgraded my filter. This one has a pick up opening almost twice the size as OE. This eliminates any pump cavitation at high RPM.
Stock Filter.
Upgraded Filter
This is what I use to fill 6L80E's. You fill the bucket, then pump the handle. It pressurizes the bucket then will fill the trans. Much easier than doing it one quart at a time. It also comes with various adapters for different filling locations.
MRGOODWRENCH3 is offline   Reply With Quote
Old 06-22-2012, 09:41 AM   #33
SS King
SS King's Avatar
Drives: a Panty Dropper
What about the fluid in the tq converter doesn't the car needs to be running to circulate that out.
SS King is offline   Reply With Quote
Old 06-22-2012, 10:04 AM   #34
MRGOODWRENCH3
You would need a fluid exchange machine to get all the fluid out of the converter. It is still important to clean the magnet in the pan and change the filter.
Old 06-23-2012, 05:27 PM   #35
BowlingSS
BowlingSS's Avatar
Stock Filter.
Upgraded Filter
What is the upgraded filter part number? Where did you get it?
Thanks.
Bill
Old 02-06-2013, 12:24 PM   #36
Denis
Denis's Avatar
Drives: 2010 SS
yea same question on the upgraded filter.
actually correct me if im wrong but is it a Circle D filter? seems like it is but i cant seem to find where to buy it.
Denis is offline   Reply With Quote
Old 08-16-2013, 10:30 AM   #37
10BlkSS
10BlkSS's Avatar
Drives: 2010 Camaro SS
My god just go to a dealership people, its a once in every 100k job!
Maxima SE (Traded)
Camaro SS
Hummer H3
10BlkSS is offline   Reply With Quote
Old 08-16-2013, 06:13 PM   #38
BowlingSS
BowlingSS's Avatar
I never take my baby to a dealer.
Bill
Old 09-09-2013, 03:06 PM   #39
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
I prefer to do everything myself so I know 100% that it was done correctly.
It is only recommended once every 100k miles... but spirited driving or towing (for towing vehicles) needs changed around 40-50k miles... Depends how the vehicle has been driven and what temps the transmission fluid has suffered through.
I've seen burnt trans fluid on cars with less than 35k miles on them. I prefer to keep my car in excellent condition and change diff & trans every 10k miles.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 09-09-2013, 04:48 PM   #40
BowlingSS
BowlingSS's Avatar
Ditto....
Old 03-15-2014, 09:17 PM   #41
sunshine1531
Drives: Cyber Gray 2LT RS
Is it possible to do this to these camaros? http://www.google.com/url?sa=t&sourc...62922401,d.b2I
sunshine1531 is offline   Reply With Quote
Old 03-16-2014, 12:53 PM   #42
BowlingSS
BowlingSS's Avatar
A couple of thing. The L99 does not have a dip stick or a drain plug. I replaced my tranny pan with one that is larger and also has a drain plug. I also installed a dip stick so I can fill it from the top. There is a rubber plug on top of the trans that you can remove to to fill it up. The best way to change the fluid is to remove the pan. The plug on the bottom of the pan is a level plug only. With the car level and fluid hot you fill until it comes out of the plug.
Good luck.
Bill
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 09:17 PM
Whitmoyer Chevrolet..CAMARO BLOW OUT!!! GM PREFERRED PRICING OR LESS!!!..Pix Inside Matt.Beaver Dealer Camaros for Sale 6 04-09-2010 01:27 PM
Master list of in stock/inbound Camaros @ Rockmont Frank in MD Dealer Camaros for Sale 19 03-10-2010 05:17 PM
Sealed Transmission?? Transmission fluid doesn't need change until 150k miles? DevilKnightFalcon Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 34 12-07-2009 06:32 PM
