08-03-2022, 04:01 PM | #1 |
Drives: 2020 Camaro SS 1LE Join Date: Apr 2022
1LE Good Drift/Powerslide Car?
Anyone else think this car is great for powerslides? Its become a guilty pleasure of mine to put the car in competitive mode and head on down to Mexico late at night with the exhaust in stealth mode and rip it like like I'm in Gymkhana
08-03-2022, 07:31 PM | #2 |
Drives: SS 1LE, 89 TTA, 91 GTA, 91 Formula Join Date: Jul 2019
U get it hot enough in silent mode and u run the risk of blowing the muffler apart. People have done it....
08-03-2022, 07:54 PM | #3 |
Tri-County Camaro SWFL
Is almost a 50/50 weight split so yeah. Also has plenty of power to break the rear lose. Only real issues I see is the fuel cut for a rev limiter and lack of steering angle.
08-03-2022, 09:44 PM | #4 |
Drives: 2020 SS 1LE Join Date: Aug 2020
I had no problem drifting the car in a drift event. It is loads of fun!
08-04-2022, 08:08 AM | #5 |
You can tune in a bouncy ls1 style limiter
08-04-2022, 09:10 AM | #6 |
You are absolutely right. I figured he was asking about 100% stock form. Buy it, and go.
08-04-2022, 10:51 AM | #7 |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
Absolutely! I slide mine around road courses. Not the fastest way around the track, but sooo much FUUUUN!
08-04-2022, 11:20 AM | #8 | |
Faster!!!
Drives: 2020 Camaro 1SS 1LE Join Date: Mar 2020
otherwise, yes, it works well and could be tons of fun for sure!!!! Have fun! Just open those pipes!!! |
08-04-2022, 12:16 PM | #9 |
08-04-2022, 02:04 PM | #10 | |
08-05-2022, 04:35 AM | #11 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
Holy crap! I wonder if you can run an aftermarket Corsa or Borla NPP in stealth without this issue…
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
08-05-2022, 09:47 AM | #12 |
If you’re doing a drift event, chances are the db restrictions are non existent or very loose. In other words, I can’t see any reason why one would be in stealth mode and drifting.
And if you need noise reduction on a db limited track, you’re better off getting Laguna pipes or lifting off when passing the sound tower. That was a tangent! Sorry! Yes, drift the camaro. It’s so fun and the chassis is brilliant and predictable |
08-05-2022, 09:55 AM | #13 |
Drives: 22 1LE Join Date: Mar 2022
08-07-2022, 10:49 PM | #14 |
