05-28-2022, 10:49 PM | #15 |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
Well I had AMP install a LME 416 and it made close to 700HP on the engine dyno at LME and roughly 580 to the rear wheels at AMP. This a naturally aspirated set up that I use for BOTH track and daily driving.
I pulled a small tire trailer with me to the track today and it got roughly 14.5 MPG going 80-85MPH on E85. This is a VERY efficient engine. Engine is fully forged with both ARP lower end studs and ARP head Studs.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
05-28-2022, 11:44 PM | #16 |
Drives: ZL1/1LE parts added Join Date: May 2018
Location: Somewhere around Texas pines tress and smooth asphalt
I would LME only, how about a stock motor, and 2650R with your cam? stock boost, should give you a 150 hp boost, and cooling should will be the same if not a tad better/few degrees cooler. There has been some bad press with the other brand of motors.
05-29-2022, 06:13 AM | #17 |
Drives: ZLI 1LE; 992 S; GLE 450, Denali HD Join Date: Sep 2019
05-29-2022, 06:16 AM | #18 |
I was thinking of going NA only but not sure how complex that is with all the heat exchangers in the ZL1.
05-29-2022, 07:35 AM | #19 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
While there's no doubt that the oil pump is the Achilles heel of the LT4, I question whether the OP actually experienced pump failure. The oil pump would not contribute in any way to the smashed plug issue. Looks to me like he swallowed a valve
Baby Blue
05-29-2022, 08:04 AM | #20 |
Drives: 2003 Monte Carlo SS SLP, 2022 ZL1 Join Date: Aug 2021
It appears to me like there was a preexisting issue as well, also with fouled, damaged plugs. I can't and not willing to attribute this to the oil pump....just my take.
06-01-2022, 06:48 AM | #21 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Yep, something hard was banging around in that cylinder. Your plug looks familiar.
You have a chance to overbuild, as long as money is not an issue. Go forged rotating assembly with stock-ish displacement and compression. Either ported OEM blower or a larger one and a mild cam with a fuel lobe will be quite enjoyable. Good Luck
06-01-2022, 07:40 AM | #22 |
We will now what the internals look like soon. Can in the shop for a tear down.
My oil pressure went to zero when this occured which is the reason I thought it was oil pump. What would cause the valve to break? too lean? |
06-01-2022, 12:38 PM | #23 | |
ZL1 Believer
Drives: 2019 Camaro ZL1 Join Date: Oct 2020
06-01-2022, 01:41 PM | #24 |
Geoff
Intake valve failed. It definitely was not a normal valve failure.
The head was repaired, had to replace the block and a piston Kind of a fluke failure
06-01-2022, 01:54 PM | #25 |
Dyno Show Queen LOL
Not bashing LME's work at all we know they are the best builders but that 600 700 NA number is a big JOKE. There high dyno #s come from the 5k intake manifold as it claims 50 plus hp over stock and not to mention the velocity stack attached to the not so stock TB is worth a ton as well.
a lt4 built 376 with the same compression and stroke basically all it has is a cam and ported lt4 heads doesn't make the jump from 455 hp (LT1 with 11:1 compression or there abouts) jump in to 600 plus. What I'm saying is just having forged internals with the same stroke isn't going to add any power (unless its lightweight stuff) and a cam and heads are probably worth 100 max 70 hp cam 30 hp heads. Its that bad ass intake.. so going off an even higher higher compression LT1 with 455 hp, 100 hp from cam and heads is 555 hp.. that intake is doing the magic! I want a new motor to, I want to give the wife mine before i blow it up.. she wants more power and the LT1 just isn't safe above 630 rwhp in my opinion its like me running my stock one currently at 1044 rwhp. I think the best bang for the buck is the stock LT4 crank (fix the main bearing issue of course) Summit rods - little insider I was looking at the K1 rods that work with an off the shelf no balance LT1 piston and called K1 about stock the guy assured me hint hint that he would use Summit racing LS/Lt rods in heart beat pretty much told me they make them for them. He said he had no worries making 1700 hp with them. I found a good deal Mahle pistons for 500.00. Ill probably take the parts to LME or use Morgan and Son in dallas they do motors for the guys on discovery channel. They are pretty affordable to. now I just need to decide the 30lb lighter Lt8 iron block from MAST or another Aluminum block. see pic this is my buddies motor you can see the LTX manifold, TB, and velocity stack.
06-01-2022, 03:23 PM | #26 |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
Lots of things could have happened. It could have swallowed that valve which wrecked the piston, then the rod could have smash into the block and hit an oil main.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
06-07-2022, 02:55 AM | #27 |
verdict in, not oil pump but valve failure.
06-07-2022, 06:28 AM | #28 |
Wow! That exhaust valve had a grand ole time bouncing around on top of that piston!
As painful as that is to see at least now you know what happened and can move on. Have you settled on where and what to get for the engine replacement? Good luck and keep us posted.
