04-20-2021, 01:11 PM | #29 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Certainly. But getting into one is a much bigger initial expense. I can gap them and hellcats now anyway
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
04-21-2021, 11:19 AM | #30 | |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
The ZL1 comes with lots of great stuff; lord knows I have my fair share of ZL1 parts. If you are looking for 700ish hp, the ZL1 gets you there without a lot of additional expense. However, if you want to go over 1000, you may need an LSX block, D60 or 9 inch rear, T400 or PowerGlide trans, 15 inch conversion, etc. None of that stuff comes on the ZL1 and you would be getting rid of all the stuff that makes the ZL1 better.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
04-21-2021, 11:32 AM | #31 |
Drives: 2010 Camaro 2SS Join Date: Jul 2018
I have a 2010 2SS and did all the things in my signature. I made 536 RWHP on the dyno at Jannetty.
I love my car!!!
2010 Camaro 2SS. Summit White.
1 7/8" 304 Dynatech Stainless Headers with High Flow Cats and Ceramic Coating, Cold Air Inductions Intake System with Scoop, SCT X3 Programmer, Moroso Catch Can, Heater Hose Upgrade 3.91 Gears, Eaton TrueTrac Posi, Billet Main Caps, Ported Throttle Body 1LE Suspension. ZL1 Springs, 2.9L Whipple Ssupercharger |
04-21-2021, 12:02 PM | #32 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Yeah, for me it's all about using the correct combination of parts working in union together to create optimum performance.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
04-21-2021, 12:09 PM | #33 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Car must be in really low boost to only make that hp with a 2.9l whipple. Plus I noticed no cam
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
04-21-2021, 01:20 PM | #34 |
Yea, my friends Whippled up 2012 LS3 with a cam at 7psi made 683rwhp, and they told him he could have more if he wanted to go 10psi, he said nah, this is enough! lol
04-21-2021, 03:10 PM | #35 | |
No cam yet. Budgetary constraints, aka "the wife." But it will happen.
04-21-2021, 08:29 PM | #36 |
Drives: 2013 2SS Join Date: Mar 2014
04-21-2021, 11:57 PM | #37 | |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Tags |
2ss, 5thgen, build thread, ls3 5thgen |
