TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 07-07-2020, 01:22 PM   #1
bto131
bto131's Avatar
Drives: 2LT/RS White with orange stripes
Question Trouble removing Catch can
Hey guys,
I can’t seem to get my catch can to unscrew so I can clear it out.
Even tore up my hand trying to unscrew it. Any tips to get it off and prevent this from happening next time?
2011 2LT RS
this is my build plz check it out and give me any ideas and ur opinion
http://www.camaro5.com/forums/showthread.php?t=195089
bto131 is offline   Reply With Quote
Old 07-07-2020, 02:37 PM   #2
'10CamaroDude
Drives: 2010 Camaro LS
You may have to use an oil filter removal strap tool. That usually means someone
put it on too tight.
'10CamaroDude is offline   Reply With Quote
Old 07-09-2020, 09:13 PM   #3
BLU DUCE
BLU DUCE's Avatar
Drives: 2011 1SS/RS IBM Camaro
+1
BLU DUCE is offline   Reply With Quote
Old 07-09-2020, 09:30 PM   #4
LT1Zob
LT1Zob's Avatar
Drives: 23 LT1 / 19 Z06 / after 6 5th gens
Use a rubber jar opener pad to grip the can and unscrew, or filter removal strap like CamaroDude suggested. If it's an Elite Engineering can, remove the stupid rubber O ring. That's what is making your life miserable. Don't worry, nothing will leak due to O ring removal
"Make yourself sheep and the wolves will eat you"
LT1Zob is offline   Reply With Quote
Old 07-09-2020, 11:01 PM   #5
Silveradoss573
Drives: Camaro 1LE
Make sure if you keep the o-ring on, that it has a thin layer of lube on it. A little on the threads helps too. As mentioned above, invest in a rubber strap wrench or two. I own a standard size and one that's a little bit smaller. They work really well on things you don't want to scratch up.
Silveradoss573 is offline   Reply With Quote
Old 07-27-2020, 08:52 PM   #6
ElderJ
ElderJ's Avatar
Drives: 2014 Camaro 1LT
I have the Elite Engineering X2 catch can. Never had an issue unscrewing it, but if you guys have one, be mindful of what I found just this afternoon:
Went to empty my can (unscrewing the bottom part to empty out the oil), when I saw the entire assembly was sitting in the can rather than being attached to the upper half via the intake. How in the world the inner assembly piece wound up in the can is beyond me. I apparently underestimated the force of air being pushed through there in conjunction with all of the vibration. Not sure how else that thing came unscrewed. It was a pain trying to screw it back on without having to uninstall the catch can (I'm lazy like that sometimes). I'll definitely have to keep an eye on that thing going forward, though.
ElderJ is offline   Reply With Quote
catch can, maintainence, oil
