06-13-2017, 01:36 PM | #1 |
Drives: Yes Join Date: May 2009
2010-2015 Camaro Side Marker Blackout Kit
FREE SHIPPING in the Lower 48 states and half price shipping to Canada. Our Side Marker Blackout Kit is made from a patented high-performance self-adhesive PVC film with a polyurethane scratch resistant coating, designed to also protect the lighting surfaces from the harmful effects of chips, abrasion, and weathering. This coating is nearly impossible to scuff and employs a UV inhibitor to prevent shrinking and discoloration, ensuring that your Blackout Kit has a flawless appearance over its lifespan. The material (.030” thick) is no flimsy decal and because it is laminated with a 3M high-performance acrylic adhesive, there are no blocks of tape to show through. This thickness also allows for superior compressibility during installation without worry of creasing the material resulting in a flawless, easy installation and look. A quantity of 1 includes 4 side markers (one for each front and rear side marker on your Camaro). Get your package here: http://www.pfyc.com/pc/CA1111/CAEXT/...ckout+Kit.html Last edited by PFYC; 12-04-2019 at 07:46 AM. |
03-15-2019, 09:31 AM | #2 |
10-30-2019, 08:14 AM | #3 |
https://www.pfyc.com/CA1111.html? We finally have the solution to blacking out your 2010-2015 Camaro side marker lights. These Camaro side marker blackouts are made from premium ABS plastic with 3M clear adhesive built into the backing. Very quick and easy installation will take you less than 5 minutes to install the entire set. Laser cut for a perfect cut every time! Why these ABS blackout covers are better than vinyl: -Made from hard plastic, the DOT warning/lettering on the lens doesn't bubble up the cover like it will with vinyl. -High gloss shine just like the painted surface on your Camaro. -These will never fade, tear, rip, scuff or peel away. -Car wash safe - these are on like glue! Only to be removed if/when you decide to remove them. -Very easy to install, takes less than 5 minutes for the entire side marker blackout kit. -Matches our Tail Light and reverse light blackout kits, made from the same material. -Lifetime warranty. Should you lose one or break one, we replace no charge for the life of your car! These 2010-2015 Camaro side light blackouts are the best quality tinting solution on the market today. Application ••••• 2010 2011 2012 2013 2014 2015 Camaro all models |
04-27-2021, 08:19 PM | #4 |
Drives: 2015 camaro ls Join Date: Jul 2020
It doesn't show $24 on that link
04-28-2021, 07:41 AM | #5 |
We are sorry, the price has increased since that post was originally posted.
Thank you. |
07-09-2021, 07:22 AM | #6 |
08-05-2022, 03:55 PM | #7 |
Order yours today!!
09-01-2022, 03:45 PM | #8 |
Thank You for Shopping at https://www.pfyc.com/CA1111.html?
