08-14-2016, 05:59 AM | #29 |
Drives: 2015 RS camaro Join Date: May 2016
Seems There's always a thread on here with people having crazy electrical problems after
a vtc is installed . I guess that's why the classisfeds always have them for sale . What's the point ? They don't actually improve power or your times ,which to me seems like a total waste of money and adding a foolish risk of possibly screw up your expensive electronics . |
08-14-2016, 08:50 AM | #30 | |
Drives: 2018 1SS M6 Join Date: Nov 2014
However, it will damage the car's electronics because it changes nothing in the car's system. All the changing is done in the TC module itself. You run a bigger risk with a tune. As far as threads you see, well, yeah, these things can cause glitches from time to time. Is it the controller, is it something in the cars system? Sometimes, either or both I guess, there are several sensors involved in DBW, and any one of them can hiccup, which will cause this. But many folks get this code once a freak out, mainly because they don't understand DBW and what the controller actually does. 9 times of 10, a simple recalibration is the fix. |
08-14-2016, 09:10 AM | #31 | |
Don't know anything about the tune OP has, but if its a full tune it should take care of all the throttle issues he wants to address. When I got my tune, I did away with my VTC (and my Range device). Tune accomplished the same thing.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
08-14-2016, 07:10 PM | #32 |
Drives: '13 SS RS Join Date: Dec 2012
Have you noticed that your first photo shows fuel is empty? Second shows half.
2013 Camaro SS RS
08-15-2016, 12:06 AM | #33 |
Hahaha yeah, right when I entered the gas station, it went to power reduced mode, then got gas, then turned car on and check engine light was on
Have a good day!
08-15-2016, 12:07 AM | #34 |
Also I did nothing to fix the issue... I plugged in my tuner, and cleared the code and I was good to go.. Hasn't came back so far
Have a good day!
08-15-2016, 09:52 AM | #35 |
Drives: 2015 Camaro 2LT/RS 2017 XL1200C Join Date: Sep 2014
I've thrown that P2138 code a half dozen times. Always after hitting a large bump in the road. All my VTC connections are tight. Checked multiple times. Been through the recalibrations. I'm starting to think there might be a loose connection inside the VTC box.
2015 2LT/RS Black -w- CGM Rally Stripes. CAI, Elite CC, Apex air scoop + w/b kit, JacFab ported IM/Extendolator, Solo HFC's, Corsa Sport Cat-Back #14953, GM strut brace, GM stealth splash guards, GM premium floor mats, Defenderworx two tone sills, Emblem Pro LFX hood emblems, FR41-20x9/20x10 gloss black wheels, OK91/93 - OKTCM Tune.
08-15-2016, 09:57 AM | #36 | |
Happens to me about every two, three months for the last year and a half.
08-15-2016, 10:00 AM | #37 |
Drives: 2013 2SS/RS Convertible Join Date: Jun 2015
If you can clear the code with your tuner and want to keep the VTC I'd say go for it. I'd only worry about going into limp mode on the highway or in a situation that could put you in danger
Sent from my SM-N920V using Tapatalk |
08-16-2016, 01:28 PM | #38 |
Drives: 2017 50th Anniversary 2SS Camaro Join Date: Jan 2016
Tags |
check engine light, reduce engine power |
Thread Tools | |
