03-16-2016, 06:18 PM | #1 |
Drives: 2011 ls camaro Join Date: Dec 2014
Nitrous 100 shot
So I tried the 50 shot on my kit. Not impressed. At all. My question is the 100 shot how safe is it? I have stock plugs and a ton of bolt ons dyno tuned.
the 50 shot runs at 11.0 so it's rich So i want to try 100 But is it for sure going to blow or can I do a run and see what my afr is to see if it's okay to run |
03-16-2016, 06:19 PM | #2 |
Nitrous 100 shot
You need to use colder plugs and have a tune for the nitrous.
03-16-2016, 06:25 PM | #3 |
Drives: 2015 Bright Yellow 6-Speed Manual Join Date: Sep 2014
colder spark plugs would help
03-16-2016, 06:44 PM | #4 |
Drives: 2012 Camaro 2LT RS Join Date: Mar 2012
You need to at the VERY MINIMUM pull some timing from your tune about 6 to start. Colder plugs are a safer step to add in the mix.
06-27-2016, 12:50 AM | #5 |
okay so i hit some money issues but im back on my feet i went with brisk 14rrys silver plugs going to go back to my tuner once the plugs are in. really excited for this, have been adding things to my set up for over a year now to run it right about to get there finally
06-27-2016, 09:02 AM | #6 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
I think you bought the wrong plugs...Aren't the YS plugs an extruded tip plug. You want a NON extruded plug. Less chance of it being blown out.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
06-27-2016, 09:22 AM | #7 |
shit really? i even emailed brisk about using those plugs they said that those plugs would work fine for both nos and daily driven. ( i dont drive my car often but i will when riding season is over) dont think the order has shipped yet should i try and cancel?
06-27-2016, 09:35 AM | #8 |
if you can catch it in time, tell them to swap it out for the Non extruded tip...wont have the "Y" in the part number
06-27-2016, 10:10 AM | #9 | |
http://www.briskusa.com/spark_plug/rr15s_spark_plug im thinkiing those are it correct |
06-27-2016, 10:13 AM | #10 |
just called them found it your where right on brisk rr14s
06-27-2016, 10:23 AM | #11 |
You got lucky in the timing of your post
06-27-2016, 12:08 PM | #12 |
08-14-2016, 09:02 PM | #13 |
Drives: camaro v6 2013 Join Date: Dec 2015
has anybody ran 100 shot on a stock engine?
08-14-2016, 09:52 PM | #14 |
I run a 75 shot and I know people have gone up to 150 shots.
