dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Interior Parts & Accessories
Old 05-17-2015, 12:43 PM   #1
Dorwd71
Dorwd71's Avatar
Drives: 2016 2SS
door abl kit from Gen5 DIY
I have the Door ABL Kit from Gen5DIY looking to sell, kit includes the Ice Blue LEDs and the light pipes. Would cost $90 new plus shipping, willing to sell for $50 shipping included.
Dorwd71 is offline   Reply With Quote
Old 05-19-2015, 09:49 PM   #2
Kinmartin0789
Kinmartin0789's Avatar
Drives: 2018 Camaro 2SS Red Hot
So I already have the door lights from the factory was this to add it to one without? Or to finish the bottom piece? I'm trying to finish the dash lights.
Kinmartin0789 is offline   Reply With Quote
Old 05-20-2015, 04:50 AM   #3
bork_bork
bork_bork's Avatar
Drives: 2013 ZL1 M6 Convert Triple Black
I believe its the dash
bork_bork is offline   Reply With Quote
Old 05-20-2015, 12:57 PM   #4
Dorwd71
Dorwd71's Avatar
Drives: 2016 2SS
it was purchased to add to car without ABL, but you can use this to add to bottom of door or to add to dash, DIYs on that and only require you to cut the light pipes and tap power for the lights.
Old 05-20-2015, 02:54 PM   #5
Ben Thur
Ben Thur's Avatar
Drives: 2010 Silver 1LT/RS
Does this come with the mounting hardware for the door inserts?
Ben Thur is offline   Reply With Quote
Old 05-20-2015, 03:29 PM   #6
Dorwd71
Dorwd71's Avatar
Drives: 2016 2SS
It doesn't come with mounting hardware
Old 05-20-2015, 06:36 PM   #7
Kinmartin0789
I'll message gen5diy to see if he can help.
Old 05-20-2015, 07:45 PM   #8
Dorwd71
Dorwd71's Avatar
Drives: 2016 2SS
Gen5diy might have it, but I didn't order the mounting hardware if it was available
Old 05-20-2015, 08:09 PM   #9
Kinmartin0789
No not for mounting hardware, I'm looking for instructions! I'm scared lol
Old 05-20-2015, 09:06 PM   #10
Kinmartin0789
Ok two questions to confirm, first are the ice blue leds the ones to match the factory ones? And is this the complete plug and play kit? If it is I'll buy it.
Old 05-21-2015, 01:06 PM   #11
c.bizz
Drives: 2011 Camaro RS
I am interested just wondering if I will need anything else to install these and have them ready to go (mounting to the door).,
Let me know please
c.bizz is offline   Reply With Quote
Old 05-21-2015, 01:50 PM   #12
Dorwd71
Dorwd71's Avatar
Drives: 2016 2SS
I will post up a pic after work showing what it will look like installed on a door panel. These are the standard Ice Blue LEDs. Also for install you will have to t-tap the wires to the window switch unless you have your BCM reprogrammed.
Quotes from others on this
Originally Posted by KMPrenger
What does it take to get the ABL in the doors working on a 1LT?
When I replaced my door panels I saw the plug in for the ABL in the doors, but my understanding is that in the non-2LT or 2SS models, that power is NOT available at the plug in. (so I didn't even try it) Do you know if that is true?
That is true the plug does not work unless you get your BCM programmed. It's a lot cheaper to just T-Tap into your window switch. It's the yellow and black wires. Plus this way you can dim and brighten your LEDs as you wish
Old 05-21-2015, 05:57 PM   #13
Dorwd71
Dorwd71's Avatar
Drives: 2016 2SS
just did a quick install of the light pipe and attached the led to it, you can see it in the pic of the door panel, I have a set not attached to car so easy to install real quick. From what I have read it is easier if you do not have abl already to just t-tap your window switch.
Old 05-26-2015, 05:53 AM   #14
Dorwd71
Dorwd71's Avatar
Drives: 2016 2SS
I've replied to all PM's I have received, if you sent a PM and didn't receive an expected reply, please PM me again.
