12-26-2019, 08:12 PM | #1 |
Drives: 2016 Camaro 2SS, 1991 Camaro RS Join Date: Apr 2012
Snag on Harmonic Balancer
Hey guys, Installing a Magnuson Heartbeat 2300 and I've hit a snag. I'm trying to get the Harmonic Balancer off and can't get the bolt broke loose. I've tried heating it up with a heat gun, Hitting with an impact gun but nothing seems to work. I have a breaker bar but that just turns the motor over. (I have automatic transmission.) I purchased a fly wheel lock and was wondering if someone could direct me to a DIY for what I need to disconnect to install the tool. Any help would be a appreciated. I worked on it for two hours tonight. The rest of the install has been great.
12-26-2019, 08:37 PM | #2 |
BAMF SS
Hit it with your purse, Nancy.
I usually just jam a screwdriver up into the inspection cover. Then breaker bar and a cheater bar
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
12-27-2019, 05:59 AM | #3 |
Drives: G8 Join Date: Mar 2012
If the screwdriver method doesn't work, the lock replaces the starter. Disconnect the battery before you try and remove the starter. Its a pain with the manifold/engine mount there. You might be able to install the lock with the starter pushed aside.
Sent from my Pixel 4 XL using Tapatalk |
12-27-2019, 06:51 AM | #4 | |
12-27-2019, 07:11 AM | #5 |
The torque from the factory is over 200 lbs of torque. Usually the heating and a kick ass impact will do it. I don't think a weak impact will do it.
12-27-2019, 01:27 PM | #6 |
Drives: 2018 SS 1LE, 2002 Z28, 1987 IROC-Z Join Date: Sep 2019
A heat gun isnt hot enough. Try using propane or MAP for about 10-15 seconds max, working around the outside circumference of the bolt head. I had a 4 foot cheater bar and mine wouldnt budge, threw just enough heat at without melting the crank seal and it broke free easy.
12-27-2019, 01:30 PM | #7 |
He got it out, I gave him a recommendation that worked.
12-27-2019, 06:02 PM | #8 |
