Old 11-20-2021, 07:41 PM   #1
Duramacr1
2Spdsy
Duramacr1's Avatar
Drives: 2021 Camaro LT1 A10
RC COMPONENTS SK Bandit 17x4.5 wheel weight
. You can’t beat the price and the looks for 225 per wheel. Ordered the rear ones too but haven’t come in yet. Lighter then racestars and cheaper . I think they look better too. I figure the rear ones are 19-20lb and they are like 40 bucks more a piece . Never seen any 6th Gen with these so thought I might throw them out there for you budget wheel guys that don’t want to spend 1000 per wheel on
Welds, Belaks, etc
Duramacr1 is offline   Reply With Quote
Old 11-30-2021, 05:33 PM   #2
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
Originally Posted by Duramacr1 View Post
Attachment 1085180
Attachment 1085181
Welds, Belaks, etc
Where do you get the RC components wheel ? and are the rears 17x10?
lt4camaro is offline   Reply With Quote
Old 11-30-2021, 07:14 PM   #3
Trochoidal
Drives: 2017 Camaro 2SS A8
Tempting!
https://www.summitracing.com/search/...20%28Search%29
Old 12-29-2021, 07:55 PM   #4
Tripwire1124
Tripwire1124's Avatar
Drives: 2022 LT1 Camaro
Any updates on the rears? Been eyeballing these for a minute, curious about the weight if the rears.
Tripwire1124 is offline   Reply With Quote
Old 12-29-2021, 11:52 PM   #5
Duramacr1
2Spdsy
Duramacr1's Avatar
The rears are exactly 20lbs
Old 01-05-2023, 07:22 AM   #6
Sillysspeed
Drives: 98 Camaro
Did you get them mounted on car? Did you go with a 27-28” front tire? Thanks
Sillysspeed is offline   Reply With Quote
Old 01-05-2023, 10:12 AM   #7
lt4camaro
lt4camaro's Avatar
BTW sillyspeed, the VMS wheels 18x5 and the rear 17x10 wheels can be bought for 260 per wheel and the 18 inch fronts will clear any brake set up.
Wait for mine , by June I will be done using what I have.
Old 01-05-2023, 09:49 PM   #8
Sillysspeed
Drives: 98 Camaro
I have the standard SS brakes so 17” should clear fine. Just worried about the front tires being similar height to rears
Old 01-06-2023, 08:21 AM   #9
lt4camaro
lt4camaro's Avatar
28 " 305 45 17 rears and 28" fronts to match. The 28 inch tall fronts for max roll out advantage when you break the your first beam at the track and a slower front wheel speed . I also thought down the road when I sell the drag pack, the fronts will work on a 6th gen brake configuration or Ctsv caddy.
Old 01-15-2023, 07:42 AM   #10
Sillysspeed
Drives: 98 Camaro
It would be nice if RC made these fronts in 18”. Just curious what they look like with a 27-28” tire on front with the 17”
