03-30-2021, 09:07 AM | #15 | |
You don't need to invest 20k into a SS to make stock ZL1 power. Sure there are going to be shops that offer grossly over inflated quotes to make average power. A lot of these shops don't want to take a car in as a project unless they are spending big money these days. I could take a SS and make 550whp for 6k. LT4 supercharger used 1500.00, LT4 install kit 3k, Install and tune 1500.00. DO the labor yourself and save a rack. LT4 supercharger works well on the LT1 for modest power levels being you can spin it slower with a larger pulley and make ZL1 power more consistently. For another 1200.00 you could put the LT4 fuel system in and run E60 and make 600whp pretty easy on 7-8psi.
2016 NFG 1SS A8
03-30-2021, 10:21 AM | #16 | |
Drives: 2016 Camaro SS Join Date: Sep 2018
03-30-2021, 02:21 PM | #17 |
Even buying a new blower like a Whipple or Maggie and you might have 12,000 in it. If you can do the labor yourself less then that
03-31-2021, 01:50 AM | #18 |
Drives: 2017 Camaro 2ss Join Date: Oct 2017
I'm also new to the boost game. My mods are as follows.
-stock msd manifold -lt5 tb -SE headers, full exhaust -alky meth kit -stock lt1 fuel system -procharger stg2 D1X @9.5psi Making 640rwph and 551 tq |
03-31-2021, 09:12 AM | #19 |
If you are running 100% meth I would reconsider. Pump gas and meth is a common combination that burns up a lot of these stock LT1's. While the Meth may lower IAT's it is actually increasing cylinder temps and that causes rings to expand. No bueno on a engine with tight ring gaps to begin with. My advice would be to do LT4 fuel system and run E60 and meth. The E will pull heat out of the cylinder and keep the rings from expanding.
2016 NFG 1SS A8
03-31-2021, 02:17 PM | #20 |
Drives: 2013 Camaro SS 1le Join Date: Sep 2018
Yeah, I'm new to the boost scene for personal use but I knew that was high for me. He wanted to do all the internals pretty much from the heads up. Just not looking to drop that much, my wife would probably divorce me and take the car anyway,lol.
03-31-2021, 02:20 PM | #21 | |
03-31-2021, 03:55 PM | #22 |
BAMF SS
Results in signature.
Stock longblock Stock cam Ran.... a little hard....
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
03-31-2021, 04:27 PM | #23 |
Drives: 2020 LT1 M6 Join Date: Jan 2016
05-15-2021, 11:49 PM | #24 |
That guy
At what point do you get concerned and advise a customer to upgrade pistons? Have you ever tried pushing an LT1 toward the 900hp numbers you're getting out of the LT4 builds?
James Montigny
2017 Camaro 2SS A8 - Krypton Green Magnuson 2650, TSP Head/Cam, DSX Low Side, Flex Fuel, LT4 HPFP, 103mm TB, Big Gulp. |
05-16-2021, 08:34 AM | #25 | |
Above double I prefer to upgrade the internals. I know I can make 900 RWHP on a stock long block on high quality fuel, proper fuel supply, and tuning but I expect it won't last very long, it would be a dyno queen. The biggest hurtle is the DI fuel supply cost. We have been 2 1/2 times stock power on LS many many times and the LT is actually a better foundation. Ted.
www.jannettyracing.com
05-16-2021, 10:53 AM | #26 | |
That guy
James Montigny
05-16-2021, 11:18 AM | #27 |
Drives: 2017 Camaro 1SS M6 Join Date: Jul 2017
I've always wondered, at what point do you need to upgrade the valvespings to prevent valve float under boost? I know LS truck engines really need it at anything past 10 psi but how do the LT1 valvesprings stack up?
05-17-2021, 07:43 AM | #28 |
We run in to octane and fuel system limitations before valve springs.
