09-27-2017, 01:29 PM | #1 |
Drives: Nightfall Grey 2.0L Turbo Join Date: Jun 2016
OEM Wheel Touch-Up Paint?
Hey GEN6 peeps,
So I noticed I got a huge rock chip on my passanger front wheel. I have the 16' RS Nightfall Grey W/ Gray accent wheels. Is there a way to touch up the wheels? Thanks everyone. EagleRS Here is a photo of my wheel color. |
09-27-2017, 01:42 PM | #2 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
I have the same wheels and have done the job.
Start with Dremel tool attachment #952 cone shaped aluminum oxide grinding stone and grind down the burrs the best you can. Doesnt have to be completely smooth just rounded. Change to the #413 sanding disk and try to round it perfectly as you can. Get some metal filler epoxy and try to form a new "rim" by molding the epoxy as it hardens. Wet sand lightly with 1200 grit and then 2500 grit. I used touch up paint Subaru 262 Quicksilver ASU 1345. Have fun!!! It's an easy fix.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
