03-02-2020, 05:42 PM | #71 |
Drives: Fast if no one's looking Join Date: Aug 2019
Telling people to change their shift habits is not the answer. Most of us have been driving stick for 20+ years. Some of us have more than one car, more than one manual.
The right answer is install the eliminator for 10 bucks and forget the nonsense of anyone telling you to change your shift habits. |
03-02-2020, 08:40 PM | #72 |
Drives: Camaro SS 1LE Join Date: Aug 2018
How doable is this while lying on your back? I don’t have a lift.
03-02-2020, 09:31 PM | #73 |
Drives: 2018 SS 1LE Join Date: Apr 2017
It's doable, but the space is so tight it will be a bit of a struggle. It took me a little while to get it in there. I should also mention that the first time I bought an Amazon one for $15 that said would fit, even the reviews, however the plug was slightly different and made my struggle that much so. I paid $25 on one of the Camaro specific sites and that one was a perfect fit.
03-02-2020, 10:12 PM | #74 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
Very doable if you can jack it up and have jack stands to put it on.
Matt Miller
2020 SS 1LE |
03-02-2020, 10:41 PM | #75 |
small hand would help.
03-03-2020, 03:45 AM | #76 |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
It would help to back it up on some ramps or use jack stands. There are two identical plugs back there one is easy to get to (reverse switch) and one on top of the transmission, thats your target. Best $20 you'll spend on your car.
03-03-2020, 04:37 PM | #77 |
Drives: 19 SS 1LE Join Date: Sep 2019
Will this same eliminator work on a 19ss?
2019 SS 1LE Riverside Blue
BTR 225 cam, West Coast Cylinder Ported Heads, Kooks LTH with high flow cats, Lethal Garage flex fuel, LT2 ported IM, 95mm TB, Rotofab intake, AWE track, Mighty Mouse catch can, Eibach lowering springs. Built by Red Barn Racing |
03-03-2020, 05:41 PM | #78 |
03-03-2020, 06:27 PM | #79 |
03-03-2020, 06:39 PM | #80 |
03-07-2020, 08:08 PM | #81 | |
Drives: 2020 Callaway Camaro SC630 Join Date: Feb 2020
Got fooled because the message still shows on the 2019 Corvette they did for me.
2020 Callaway Camaro SC630 - MN6 1SS Satin Steel Gray
2019 Callaway Corvette SC757 - MN7 1LZ Elkhart Lake Blue |
