Old 06-19-2021, 12:36 PM   #1
taz327
taz327's Avatar
Drives: 2010 Camaro 2SS
Aftermarket Wheels
Hey people, new to the Camaro6 forum, but I’ve has a 2010 Camaro SS before. My question is: I have a set of Nitto NT555GS Tires 285/35/19 front and 315/30/20 rear off my C7 Corvette, but my C7 ZR1 Replicas are the wrong Offset, so I need to know what aftermarket wheel Offset I should use, so they won’t rub on my 2017 Camaro LS?
Will 19x10 with +23mm front and 20x11 with +43mm work?
Any help would be greatly appreciated, Thanks.
[SIGPIC]
taz327 is offline   Reply With Quote
Old 06-19-2021, 12:53 PM   #2
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
They should physically fit, but I wouldn't run them. The brake control module is pretty sensitive to tire rolling radius front vs rear, and the sizes you have are far enough from stock that I'd bet they'll cause issues as others on here have had unless someone else can chime in and confirm this size delta works.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 06-19-2021, 10:38 PM   #3
enzia35
Drives: '16 Garnet Red 1SS
Those wheel sizes fit and the difference in tire diameter is 1.9%. So everything should be g2g.
'16 Camaro 1SS
'18 Miata GT
