06-22-2021, 05:02 PM | #71 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Dang, not sure if a transmission flush change with new fluid/filter might help. I would certainly start there though. Could be a defective valve body though, hopefully not the transmission clutches which would typically cause slipping.
06-22-2021, 08:40 PM | #72 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
Trans fluid and filter changed at around 8000 miles
06-22-2021, 08:45 PM | #73 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
So back on track, nobody that has gotten this mod has chimed in so it’s safe to say not worthwhile unless you are cammed?
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
06-22-2021, 09:07 PM | #74 |
Drives: 2021 Camaro 1LE Join Date: Mar 2021
06-22-2021, 09:13 PM | #75 |
You are free to disagree, I'm telling you that two highly regarded shops said there's nothing to be gained without a cam or unless you have a really high HP application where torque management is in effect but you're going to have a cam before you reach that level.
06-22-2021, 09:18 PM | #76 | ||
06-23-2021, 07:58 AM | #77 |
Petro-sexual
Is that slow shifting on a stock tune? If you're not on a stock ECM-tune, and someone tuned it for you, it could be a spark table contributing to the issue. But - I know my car, at low-load and high-RPM will shift a lot slower. I wonder if that's what you're talking about. Anyways - there is a little cheating you can get with shift feel that pre-T93-owners were tuning before they could unlock their T87as. Anyhow - I could also be way off, lol...
It would seem to me if this were a worth while investment, you should have the same tuning capabilities as the earlier TCMs - hopefully. I think torque management is the largest benefit, from what I can tell. There are the obvious RPM/quickness/speed/etc. changes, but I think the TMA is the biggest benefit. On a car I know, it's hard to tell if the TMA is coming from the torque tuning, or if it's coming from the TCM. I feel like you might get to a point to where the combination dictates a certain amount of torque request for the engine to keep the throttle open and spark at commanded advance, and that point might be pretty easy to reach and the T93 just starts to shut things down to save the drivetrain. That's all speculation. Maybe that 700-mark is where that starts to be an issue? What I wonder is if these T93s have full functionality (e.g. does this TCM still have all of the different drive modes and all that). I forget how many shift patterns there are, depending on mode and such, but are those all there like factory? It's a lot of money to spend, IMO, if they aren't there, like stock.
06-23-2021, 08:15 AM | #78 | |
2016 NFG 1SS A8
06-23-2021, 08:20 AM | #79 | |
06-23-2021, 09:10 AM | #80 |
Drives: 19 ZLE A10,17 SS 1LE, 16 C7R,CT5V Join Date: Feb 2017
For an A10 car it doesn’t shift where the new power Is made if you have a cam. Have to tune to use the power.
Sent from my iPhone using Tapatalk |
06-23-2021, 10:35 AM | #81 |
Petro-sexual
I wasn't there (obviously) for the conversation with the other shops saying there is nothing to be gained, but there's probably a lack of context that is missing, somewhere along this line of information.
I've seen those Pray posts, too, and it's also easy to see the TM from stock tunes, on stock cars in the logs. Perhaps, when it was said there were no gains, the response was from a power-angle. You won't necessarily make more power than the combination is capable of, however, gains can be made to optimize the tranny tune to use the power the combination is capable of making. Tuning for a cam, as already said, that makes power past the shift point of OEM-tuning, will most likely yield gains, but without shifting at higher RPMs, you won't be accessing that power. It'd be nice to see exactly what's going on with this new option. If I understand correctly, the guy over at HHP has been around a while. I recognize his name from like 2-decades ago in the LS-world. I'm sure this is legit, but it's a lot of money to spend without too much information.
06-23-2021, 10:59 AM | #82 | |
Rotofab Big Gulp NW 103mm TB Ported OEM blower Kooks 2" headers Kooks green cats AWE catback exhaust PCM tune 700whp The answer from Vengeance Racing was no benefit with my current mods without a cam, and Jannetty Racing said my money would be better spent on a 2650R blower and a cam. |
06-23-2021, 05:38 PM | #83 | |
06-23-2021, 06:23 PM | #84 |
I wonder if there's more to be gained on the A8 than the A10 by TCM tuning because Vengeance and Jannetty don't seem to think its worth doing at 700whp without a cam. You and King both have A8s and probably both have TCM tunes so maybe you are seeing decent gains even in a stock vehicle but maybe it just isn't necessary on the A10 until its time to raise the shift points or torque management becomes an issue with high HP applications.
