10-08-2020, 07:37 AM | #57 | |
Who Needs to KNOW?
Design of pillar layout may have had influence on results - i dont recall seeing any pillar spaced like THAT! Looked like value brand peperozi pizza. While other models looked realistic - in terms of matching actual production pieces, the pillar version was oversimplified and skewed the results.
ing for grip.
10-08-2020, 10:00 AM | #58 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
It's the thermal ranging - the algebraic ranges of the thermal transient terms (there are three of them in most thermal transient stress analyses, four when you consider the effects at the junctions between thick and thin sections of the part in question) between the 'ups' and the 'down's that establishes an alternating stress intensity. Which from there is how you'd estimate fatigue usage and expected service life. FWIW, no two of these thermal transient terms necessarily peak at the same time, and generally do not. You really have to look at the transient portion of a braking event, not just the "final" thermal state when you first lift off of the brake pedal. Norm
'19 WRX 6M (the family sedan . . . seriously) |
10-08-2020, 10:11 AM | #59 | |
Norm
10-08-2020, 10:26 AM | #60 |
so what do you guys think in your opinion is the best option for a weekend fun car/track toy when the time is needed to replace these?
10-08-2020, 11:42 AM | #61 |
Who Needs to KNOW?
a BRZ/86 Much lower consumable cost. In mean time, wheel spin on demand it is.
ing for grip.
10-08-2020, 02:09 PM | #62 |
Drives: ZL1 1LE Join Date: Oct 2016
Having not read the entire thread, and also having a ZL1 (I believe you guys are mostly talking about SS 1LE), I'm going to admit something. I'm still on my first set of OEM rotors. I don't know how many track days I have on them now, though the majority are with OEM pads. It's got to be 30+, the last three of which are with DTC70's.
Current measurements are between 35.22-35.9mm depending on where are the rotor. I would give a +/- 0.3mm due to this being a cheap Amazon gauge. If I remember correctly, discard thickness is 34mm. Tires varied between OEM 3R's and take-off slicks and many others in between. Rotors can be had for $359 from RockAuto. Seems like the obvious choice for rotors, does it not?
10-08-2020, 09:22 PM | #63 |
Seanblurr:
Yep I’m just playing devil’s advocate. Unless your racing (wheel to wheel, or TT) your primary concern should be tuning the “nut behind the wheel” and keep consumable cost low so you can maximize practice. |
10-09-2020, 09:27 PM | #64 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
10-09-2020, 09:39 PM | #65 | |
BTW, Sean is one of the fastest track rats here and on his 2nd Camaro Cheers! |
12-17-2021, 11:13 AM | #66 |
time to replace my rotors next year and my buddy had some spare 1le ones going to try some girodisc rings wish me luck haha
12-18-2021, 08:10 AM | #67 |
I've used both DBA and Girodisc. Not really much difference at all. Changing rings is part of my annual track maintenance. Rebuilt the calipers (glad I did) with vented pistons, new seals etc and interested to see how they work out.
