Old 03-30-2021, 09:01 PM   #1
17MaroSS
Drives: 17 2SS 6sp
After AEM install, screen reads "test"
Hello everyone. I just finished installing full bolt ons and after installing a AEM wideband and starting the car, the screen just reads "test". The mode and set buttons don't change anything and there's nothing written about it in the manual. I would appreciate some help here. Thanks in advance!!
FOR SALE 17 2SS 6spd h/c/i/fbo
17MaroSS is offline   Reply With Quote
Old 03-31-2021, 01:17 AM   #2
Herold Motorsports
Herold Motorsports's Avatar
Drives: 2017 Chevrolet Camaro SS
Which aem did you install?
Usually if an aem unit gets stuck on test or heat up mode the power source for the gauge isn’t a strong enough or reliable source. Where are you getting 12v from?
Herold Motorsports is offline   Reply With Quote
Old 03-31-2021, 09:48 AM   #3
17MaroSS
Drives: 17 2SS 6sp
It's the aem 30 0334. I didn't know a switch can be weak. Thought it either has power or doesn't cause it's a 12v car. No? This is where i put it
Old 03-31-2021, 04:42 PM   #4
NA18CamaroSS
NA18CamaroSS's Avatar
Drives: 2018 Chevrolet Camaro 2SS 1LE 6M
Double check your ground. Connect the power directly to the battery. If your power and grounds are good, you may have a defective unit. The next step would be to contact AEM.
Bolt-ons.
NA18CamaroSS is offline   Reply With Quote
Old 03-31-2021, 06:15 PM   #5
20Bluezl1
I took my power from the cigarette plug and no issues. I doubt it's a power issue snice you want directly from a fuse. Are you sure your on the correct side of the fuse?
20Bluezl1 is online now   Reply With Quote
