09-17-2020, 10:42 PM | #1 |
Drives: 2016 2SS 6MT Join Date: Apr 2020
Wideband not showing up in HP Tuners
Anyone have any advice on how to get the wideband data to show up on hpt software. The gauge itself works, I added the wideband to the parameter list, but once I connect the car and start it up, that the wideband part on the list goes blank. I also see that there are multiple channels. Could it be because I added the wrong channel? Getting remote tuned, pretty much I've gotta figure this out to log correctly.
09-18-2020, 05:41 AM | #2 | |
09-18-2020, 06:34 AM | #3 |
That's the wideband I have. I need to add the AFR to the list so that my tuner, Brett can see it to fine tune... I followed the video by HPT on Youttueb showing how to do this. I can see it on the list, but once I press record it disappears and that line goes blank...
09-18-2020, 07:07 AM | #4 |
Drives: 18 Z1E - 18 Raptor - 17 Jeep SRT Join Date: Dec 2019
Type in WB EQ it will be under oxygen sensors not X Series UEGO. At least this was the case with mine the other day, I was having the same problem.
09-18-2020, 07:26 AM | #5 |
Drives: 2017 ZL1 Join Date: Jan 2017
Agree, look for WB EQ 1 (SAE) and add that as a channel. Make sure to connect to the car after it has been put in run (not started or started) then start recording or it may not show up.
09-18-2020, 08:45 AM | #6 |
Try to repoll all parameters after you connect the scanner(with the car on and not running... in accessory mode) so it will see the wideband.
2016 NFG 1SS A8
09-18-2020, 12:34 PM | #7 | ||
09-19-2020, 01:05 AM | #8 |
thanks for everyones help! Im gonna try this later
09-19-2020, 08:06 PM | #9 |
Drives: 2020 ss Join Date: Nov 2019
If what everyone said above doesnt work..Go to the settings on the AEM wide band. If you see CAN you need to send the gauge to AEM. If you see OBD you are ok. AEM put the wrong firmware in some gauges . I just just went through this issue and come to find out I had the gauge with the wrong firmware.
09-20-2020, 04:18 PM | #10 |
Drives: 2019 Camaro 1LE Join Date: Dec 2019
I had the same problem. I was using the Bluetooth to log. As soon i hardwired to laptop...problem solved.
10-22-2020, 08:22 PM | #11 | |
10-25-2020, 04:38 PM | #12 |
I had to destroy mine too. I was trying to get it to work for 3 days smh. Glad you got it fixed.
2020 Camaro SS
Heads,cam,hi-ram,hhp tcm |
04-13-2021, 05:49 PM | #13 |
Drives: 2017 SS 1LE Join Date: Mar 2017
I have the same problem. Says odb, but channel disappears when you start to log. Any other ideas?
04-14-2021, 05:15 AM | #14 |
Just do this and you will be fine:
Find WB EQ 1 (SAE), add that as a channel. Make sure to connect to the car after it has been put in run (can be engine on/off) then start recording or it may not show up
