Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > ZL1 Parts
Old 01-13-2018, 12:38 PM   #1
ss/rs/378
ss/rs/378's Avatar
Drives: 2012 ZL1 Camaro Victory Red
Livernois Duel Fuel Pump
I Have a Livernois Duel Fuel Pump for sale it will support 800 rwhp and with the help of a external fuel pump will work with e85 it will fit 2010-2015 Camaro SS or 2012-2015 ZL1 this unit has less then 1500 miles on it if you where to order it you would pay $899.99 I will let it go for $650.00 shipped!!!
2.55 UPPER PULLEY,100MM IDLER PULLEY,160 STAT,PORTED TB,PORTED SNOUT,MSD PLUG WIRES,NKG PLUGS,KENNE BELL EXTERNAL FUEL PUMP,2"KOOKS HEADERS,HIGH FLOW CATS,3"CORSA 60LB DEKA INJECTORS TUNED BY FROST 580RWHP,571RWTQ.
ss/rs/378 is offline   Reply With Quote
Old 01-13-2018, 07:41 PM   #2
R3VoLuTioN
R3VoLuTioN's Avatar
Drives: 2011 1SS RS Synergy
Does it have everything needed to install? Why are you selling?
R3VoLuTioN is offline   Reply With Quote
Old 01-17-2018, 10:28 PM   #3
Gotit4cheap16
Drives: Victory Red
Still available? By external pumps do you mean new dual pumps like the 300c pumps?
Gotit4cheap16 is offline   Reply With Quote
Old 01-18-2018, 11:46 AM   #4
Gotit4cheap16
Drives: Victory Red
There was another seller that said he dropped dual 300c pumps in his and was fine. Are the current pumps in them not E85 Compatible?
Old 01-20-2018, 09:35 AM   #5
GAPPED
Drives: Whippled Camaro
Good pump no issues up to 800hp on E85 cant beat it for the money I had BAP on it while the stock pumps was in it and it was fine at 750hp i went to the 300c pumps and ditch the bap (which is forsale now)
GAPPED is offline   Reply With Quote
Old 01-21-2018, 05:31 PM   #6
lionssfan
lionssfan's Avatar
Drives: 2010 2ss camaro
pm
2012 zl1 stock 7000 miles
2010
TVS2300, BTR cam PD stage 3, ID1050 injectors, CHE bronze trunnions, 7.400" pushrods,.660" lift platinum springs, Titanium ret, Zl1 fuel pump, Kooks LT headers, High flow cats, Roto Fab CAI, Corsa exh., Mellings oil pump, HD chain, ls2 damper, all synthetic, BMR control arms, zl1 toe link, BMR cradle mounts, W/bottle relocation, air scoop deflector, Hennessy wheels, two piece rotor, morimoto fogs, DRL harness, coilovers, Heads up install, mgw shifter, slps splitter, slp spoiler, zl1 side skirts, painted strips, debadged, tinted, 2018 emblems.
Edit Signature
lionssfan is offline   Reply With Quote
