Old 02-04-2015, 08:10 AM   #15
H-E
Drives: 2010 zr1 Camaro 2011 vert
Originally Posted by Bad70supreme View Post
This is what I was thinking too. I would like the spray a 100 right off the hit, all the way down. I don't see why that wouldn't get me in the 10.9-7s at lest.
Bo I might step up to 150 progressive, but I would like to start small for now. My car hits the tires pretty soft, so I think with the 100 out it will act like I put a gear in it.
You would be faster and your engine would be happier with a progressive 150..
H-E is offline   Reply With Quote
Old 02-04-2015, 09:12 AM   #16
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
I agree. This will be the final setup for me, due to cost I will have to start smaller and work my way into that though. I might even start with 75 my first time out, this is something I want to grow into.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 02-06-2015, 01:50 PM   #17
Rdunn
Really, Really Fast
Rdunn's Avatar
Drives: 2010 Camaro SS
I set mine up on a button. I would leave then hit the button at the 60' mark. Ran for 2 seasons on the stock diff and trans w/o a problem
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is offline   Reply With Quote
Old 02-07-2015, 09:51 AM   #18
se7en
Drives: 10 Procharged SS
What size shot you hitting Ryan?
10 Camaro: Built 376, LSA Heads, BTR valve train and Stage III Camshaft. F1A 12 Rib-3.75 pulley (17psi), Squash Dual Fuel System with Return (Dual Walbro 450LPH on a Hobbs Switch), Aeromotive regulator, Holley Fuel Rails, ID1300's. RMVB 4L80, 4K Stall, and Trans-brake. 9" IRS, 3.50 gears with a full spool
se7en is offline   Reply With Quote
Old 02-07-2015, 10:18 AM   #19
Rdunn
Really, Really Fast
Rdunn's Avatar
Not running it anymore, but it had a 100 shot
