07-06-2014, 07:23 PM | #1 |
Drives: 2012 ZL1 Camaro Victory Red Join Date: Jan 2013
Isolator Reimbursement Request Form
Over the weekend I received my form from GM on the problem with the isolator it stated that if you are getting the rattle you can take your Camaro in to have it replaced and that everything would be covered but it also states if you have had it replaced you can request reimbursement from GM so I am filling this form out my question is I went to my local Chevrolet dealership and asked them about this issue when I first found out about it they said they didn't have anything about it on file this was probably 6 months ago but I didn't want to take any chance of damage so I had a local shop replace it with a solid isolator when they took it apart there was noticeable damage already to the shaft and I do think I can show pictures of this damage but I never did here the rattle that they claim will happen so what I want to know if anybody else has had someone besides a GM dealer replace there's and if you did in fact get reimburst from GM or would it be a waste of my time even though I originally inquired about the problem I don't know if this has been covered if it has I appolgize for the repost!!
2.55 UPPER PULLEY,100MM IDLER PULLEY,160 STAT,PORTED TB,PORTED SNOUT,MSD PLUG WIRES,NKG PLUGS,KENNE BELL EXTERNAL FUEL PUMP,2"KOOKS HEADERS,HIGH FLOW CATS,3"CORSA 60LB DEKA INJECTORS TUNED BY FROST 580RWHP,571RWTQ.
07-06-2014, 07:44 PM | #2 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
I just received the same notice in the mail. I'm going to call my dealer tomorrow. Per the instructions; you can seek reimbursement through the dealer or through GM directly by mailing the required form and supporting documentation.
07-06-2014, 08:00 PM | #3 |
Yes I know that but did you have it replaced yet and if so was it a GM shop or a independent shop?
07-09-2014, 08:27 PM | #4 |
Drives: 13 Camaro ZL1 Join Date: Apr 2014
Could you post a copy of this letter? I have yet to receive anything. ..
07-10-2014, 04:06 AM | #5 |
Drives: 13 ZL1 SIM, 99 Z28 Black Join Date: Feb 2013
I haven't done anything to mine yet, but you might consider that this is an SC bearing issue not necessarily an issue with the isolator. They replace the entire SC. You will note in your letter it says if you have a problem it will eventually lead to bearing squeal. It doesn't say anything about isolator in the letter. I suspect the reimbursement form is if you already had the SC replaced. I suppose they could even deny warranty repair if you changed the isolator. Not sure, but something to look into.
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
07-10-2014, 06:17 AM | #6 | |
Thread Tools | |
