04-02-2024, 04:24 PM | #1 |
Labor Rates
I have a 2017 1 SS that has an unlocked TCM, flex fuel sensor, AWE axel back and tune already done. I got a quote for $2700 for Speed Engineering 1 7/8 LTH, 3 inch X pipe and custom tune. Is that on par for getting things like this done? The exhausts was $700 and $1000 for labor and $1000 for tune? Thanks in advance.
04-02-2024, 04:36 PM | #2 |
Gray Ghost
Drives: 24 Camaro 2SS Loaded Join Date: Feb 2024
That sounds a bit pricey to me. These days though with everything being so inflated it might be about right?? One can call around and get prices? Best of luck.
04-02-2024, 06:06 PM | #3 |
Drives: 2022 SS 1LE Join Date: Aug 2023
GPI seems to be a pretty well regarded performance shop. They quote about $500ish for header install. Tuning is about $800.
https://gwatneyperformance.com/camaro-services/ My local performance shop quoted me $700-800 for a tune. |
04-03-2024, 08:52 AM | #4 |
Tri-County Camaro SWFL
Big shops usually charge around $150/hr for labor.
I know tunes were 750 each time.
04-03-2024, 09:16 AM | #5 |
Drives: 2023 Camaro 1SS Join Date: Apr 2014
What's the labor rate on the estimate?
I'd assume a specialty/tuning shop would be higher than the average mechanical rate for the area. Around here, dealerships are definitely over $100/hr for basic work. |
04-03-2024, 11:13 AM | #6 | |
'20 ZL1 1LE A10,
