09-27-2023, 02:16 PM | #1 |
Drives: 2023 Chevy Camaro 2LT V6 6MT Join Date: Sep 2023
V6 front end sits a bit high? Solutions for a slight drop?
I can't not notice my fender gap in the front. The back is less so I don't think that's a problem....especially when I get new wider wheels and tires next year. Any ideas on how to lower the front? Do I have to get front and back springs? If so, I don't want the rear sitting lower than the front. I tried search but can't really find what I'm asking. I do not a ultra low look BTW.
Thanks for any suggestions and examples of solutions.
2023 Camaro 2LT V6 6MT Vivid Orange Metallic
09-27-2023, 02:22 PM | #2 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
Ground Effects / Splitter :P
09-27-2023, 02:53 PM | #3 |
Appreciate it. Front splitter is on the list for next year for sure. Specifically looking at closing the fender gap here.
09-27-2023, 02:54 PM | #4 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
If you plan on keeping the car and want some flexibility you can go with coil overs. Then you can adjust as needed. I was looking for a decent set for my V6RS until I decided to upgrade to a SS1LE with mag ride. You can find a decent set for less than a grand. You could go the spring route but then you lose all adjustability.
09-27-2023, 03:46 PM | #5 |
Drives: Camaro 2SS & ZL1 Join Date: Mar 2018
Just going off of my recent experience,, did the dealer leave in the spring spacers? I don't see them in the picture, but thought I'd mention it.
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red |
09-27-2023, 04:02 PM | #6 |
Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
This is where I’d start!
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
09-27-2023, 07:20 PM | #7 |
09-27-2023, 07:36 PM | #8 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
Your front camber is at .5 degrees neg. or less. I went 1.2 neg. camber on front . Definitely increases front grip. Probably will help fender gap a little.
B6 dampers, x pipe, mbrp axel back
09-27-2023, 09:07 PM | #9 |
Interesting. So regardless I should go get an alignment to seriously improve handling dynamics. I’ll look into this.
09-27-2023, 11:36 PM | #10 |
Monterey County Camaros
Eibach pro kit. Was about a 3/4 inch drop all around. Fills in the fender gap nicely. With a 275 or 285 tire with around a +20/23 offset it'll be just right.
And yes, a -1.2 alignment makes a significant difference. Tried a -2 but the tire was rubbing the strut so I had to dial it back a bit. There's a 1le track alignment you can find by searching.
Follow us on Instagram @montereycountycamaros
09-28-2023, 05:05 AM | #11 | |
09-28-2023, 06:10 AM | #12 |
You can effect the handling balance with camber like you can with sway bars. I did -.7 to -.8 camber on rear.
09-28-2023, 06:56 AM | #13 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Some one maybe BMR used to have what they called a minimal drop front spring, it was like 3/4" or there about. Short of not having MRC I woulda said that yes the spacer blocks were still in there.
09-28-2023, 06:57 PM | #14 |
Add a Procharger.
