07-03-2020, 05:24 PM | #1 |
Drives: Chevrolet Camaro Join Date: Feb 2020
Audio upgrade
Scheduled my 1ss 1LE for an audio upgrade and window tint in a couple weeks. Does $1900 for a dual 10” sub enclosure, 5 channel amp, rear sail panel 6.5’s, component speakers up front and full tint upgrade sound reasonable?
Roto Fab CAI
GM Performance Parts red knee pads and 1LE floor mats Mishimoto catch can GM Spectrum Lighting Alpine component speakers, JBL amp, Magnum Subs 3M tinted windows ZL1 Add Ons front and rear rock guards Stainless Works headers and x-pipe Borla ATAK axleback exhaust Dyno tuned at National Speed, 464rwhp, 493ft lbs Next up, MSD intake manifold and another set of dyno tunes |
07-04-2020, 01:24 PM | #2 |
Drives: 2023 2SS Convertible Join Date: May 2009
Seems reasonable for decent brands installed. As long as you don't end up with Tenna Pyramid Gold or something. Make sure your installer has done Camaro's like yours before too so they don't come back at you for another $1000 of adapters or something.
-Geoff
07-04-2020, 01:42 PM | #3 |
JBL Club Series amp and Alpine R series speakers. The stock 1LE audio is pathetic!
Roto Fab CAI
07-04-2020, 04:09 PM | #4 | |
-Geoff
07-05-2020, 04:25 PM | #5 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
That may well be a reasonable price. It kind of depends on your exact goals for the sound. However, I'd strongly consider not messing with the rear side panel speakers at all: upgrade the door and dash speakers and do the sub (and maybe see if there's a three-channel amp option that saves a bit of money), and just fade out the rear panel speakers. There's a fair amount of labor involved in getting to those rear panel speakers, and they don't even get a full-range signal. I don't see a benefit in using them at all, much less upgrading them.
Matt Miller
2020 SS 1LE |
07-05-2020, 06:57 PM | #6 | |
Roto Fab CAI
07-05-2020, 09:58 PM | #7 |
Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
In the stock system is the frequency range to those speakers reduced at the amp, or the head unit? If the head unit sends full range, then adding a full range amp may sound worse because the stock speakers may not be able to handle it without distorting.
07-06-2020, 07:55 AM | #8 |
The "head units" on our cars that we see in the dash is really just a touchscreen display. The real receiver unit is a module up in the dash board to the right of the glove box. In a 1SS 1LE and some base cars, there is no separate amp in the trunk at all, and the signal to the rear speakers is still altered. So the frequency is filtered in that receiver unit and not at the amp.
Matt Miller
2020 SS 1LE |
07-06-2020, 09:03 PM | #9 | |
07-06-2020, 11:35 PM | #10 |
There is no place to tap full-range speaker level outputs to those rear side speakers, AFAIK. You have an SS 1LE like I do, so the speaker signals coming from the receiver module by the glove box are the only analog signals available. If you car is 2016-2018 they could install a NAV TV unit and pull a digital signal and send that to an amp, or maybe get re-equalize the rear speaker signals to flat again. That's outside my knowledge. If it's a 2019-2020, then no such thing is available for our cars yet. Maybe there's a 5-channel amp that can take one set of speaker-level inputs (from the front speakers) and split it into five channels. But your head unit will then no longer control the fader - it would have to be some kind of adjustment on the amp itself.
Matt Miller
2020 SS 1LE |
