04-10-2019, 10:10 AM | #1 |
Drives: Yes Join Date: May 2009
2010-2015 Camaro Side Marker Blackout Kit
We finally have the solution to blacking out your 2010-2015 Camaro side marker lights. These Camaro side marker blackouts are made from premium ABS plastic with 3M clear adhesive built into the backing. Very quick and easy installation will take you less than 5 minutes to install the entire set. Laser cut for a perfect cut every time! 2010 2011 2012 2013 2014 2015 Camaro all models 2010-2015 Camaro Side Marker Blackout Kit Save 6% off your order!! Use promo code: SAVESIX |
04-11-2019, 12:47 PM | #2 |
In stock and ready to ship!
09-26-2019, 08:58 AM | #3 |
Order yours today. |
01-20-2022, 03:30 PM | #4 |
https://www.pfyc.com/CA1111.html
Product Description ••••• We finally have the solution to blacking out your 2010-2015 Camaro side marker lights. These Camaro side marker blackouts are made from premium ABS plastic with 3M clear adhesive built into the backing. Very quick and easy installation will take you less than 5 minutes to install the entire set. Laser cut for a perfect cut every time! Why these ABS blackout covers are better than vinyl: -Made from hard plastic, the DOT warning/lettering on the lens doesn't bubble up the cover like it will with vinyl. -High gloss shine just like the painted surface on your Camaro. -These will never fade, tear, rip, scuff or peel away. -Car wash safe - these are on like glue! Only to be removed if/when you decide to remove them. -Very easy to install, takes less than 5 minutes for the entire side marker blackout kit. -Matches our Tail Light and reverse light blackout kits, made from the same material. -Lifetime warranty. Should you lose one or break one, we replace no charge for the life of your car! These 2010-2015 Camaro side light blackouts are the best quality tinting solution on the market today. Application ••••• 2010 2011 2012 2013 2014 2015 Camaro all models |
09-13-2022, 03:01 PM | #5 |
Thank You for shopping at https://www.pfyc.com/CA1111.html
