08-23-2020, 09:54 PM | #1 |
Drives: 2011 Camaro 2LT Join Date: Oct 2018
JMS BAP Wiring
I’ve seen a few ways of wiring these, and some moderately heated discussion about what’s right/wrong. This is what I’m planning on doing with a target output of 17.5V. I’ll be adding an inline 30A fuse to protect the white wire going to the FSCM, since I’ll be bypassing the F12 fuse box in the trunk entirely. Input is most appreciated. Thanks
08-23-2020, 10:41 PM | #2 |
Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
Exactly how I installed mine, fuses and all. And mine is in the battery well just like FasNuf did in his youtube video. And my voltage is set at 17.5 vdc also.
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
08-23-2020, 10:50 PM | #3 |
Did someone mention my name? LOL Here's the Install Video https://youtu.be/PgeWAhuN2zM Voltage Monitor Gauge video https://youtu.be/TmeU7fCKt2Y
08-24-2020, 08:02 AM | #4 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
yup looks good. I stayed just under 17.5V 17.42V I think I got as I was told by Jannetty I should go over 17.5 and the next notch on the adjustment put me over 17.5
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
08-24-2020, 09:41 AM | #5 |
Thanks all. Nice vids FasNuf! Thanks for posting those links.
08-24-2020, 09:45 AM | #6 |
That's why I make them. So glad they help someone.
Tags |
bap, boost-a-pump, jms |
