Old 10-03-2021, 10:15 PM   #1
Ummpwr
Drives: Honda S2000
ForgeStar Wheels18x11 18x12
Hello,
Best to call or txt if interested 814-571-1854
I have for sale a set of used Forgestar wheels.
***LOWERED TO $1150*** + Shipping
Bronze in color
Front - 18x11 et 34
Tires- 315/30/18 Rival S 1.5 - VERY USED
Rear - 18x12 et 49
Tires - 335/30/18 Rival S 1.5 - VERY USED
Front spacers 25mm thick. 14x1.5 studs
Rear spacers 15mm thick. 14x1.5 studs
**They are Corvette c7 spec wheels but I sourced spacers w/built in studs to make the offset correct***
You will need to shave the front strut bracket to clear
I have used them for about a yr , driving on the street , doing Autox and track days.
I will include the spacers and tires if wanted.
I live in Charleston, SC . willing to ship at buyers expense.
Eric
Ummpwr is offline   Reply With Quote
Old 10-03-2021, 10:21 PM   #2
Ummpwr
Drives: Honda S2000
Pics
Old 10-05-2021, 10:42 AM   #3
Zl1+911
Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10
do you (or informed others) have an idea on fitment with a ZLE?
Zl1+911 is offline   Reply With Quote
Old 10-05-2021, 07:33 PM   #4
Ummpwr
Drives: Honda S2000
So I have them on a SS 1le. (I had to grind the front struts and use wheel spacers)
I would think they would fit even easier on a ZLE (you will still need the wheel spacers, but probably don't need to grind anything)
1. The zle has wider front fenders than the ss1le
2. The zle has different front struts that offer more clearance
When you factor in the wheel spacers they are basically 18in ZLE spec wheels
Eric
Old 10-16-2021, 07:17 PM   #5
Ummpwr
Drives: Honda S2000
Bump... ***LOWERED TO $1350***
Old 01-18-2022, 08:23 PM   #6
Ummpwr
Drives: Honda S2000
BUMP *** Lowered to $1250***
Old 03-01-2022, 09:17 PM   #7
Ummpwr
Drives: Honda S2000
BUMP *** Lowered to $1150***
Old 03-27-2022, 05:03 PM   #8
shogun37
Drives: none
so these are not 120mm bolt-circle but rather 120.65mm?
shogun37 is offline   Reply With Quote
Old 04-03-2022, 08:12 PM   #9
Ummpwr
Drives: Honda S2000
Correct. Although its such a slight difference I have been running them on my Camaro for over 1.5yrs and have taken them on and off many many times with no issues.
Happy to answer any other questions.
Thanks, Eric
Old 06-21-2022, 06:20 PM   #10
Ummpwr
Drives: Honda S2000
Still for sale, Lowered price to $1100
