Old 05-26-2020, 05:06 PM   #1
travislambert
travislambert's Avatar
Drives: '17 ZL1
Help with DSX Tuning Auxiliary Fuel Pump
I recently installed a Magnuson 2650 on my '17 ZL1. As part of the upgrade I installed a DSX Tuning auxiliary fuel pump kit.
In the logs, I've noticed a few issues.
  • When the aux pump kicks on, the in-tank pump backs off in an attempt to maintain the desired fuel pressure. However, when the aux pump suddenly turns off, the pressure dips significantly before the in-tank pump has the chance to get back up to speed. There's probably a way to tune around this, but I wish the DSX kit would just use a PWM pump and phase out slowly.
  • Sometimes, mid pull, I'll see dips in fuel pressure. It's not because the pumps can't keep up with the load because the pressure will recover on its own within the same pull. Something else is going on.
If anyone has experience tuning for one of these auxiliary pump kits, I could really use your help and insight.
2023 Camaro SS 1LE A10
2023 Camaro ZL1 1LE M6
2017 Camaro ZL1 M6
2016 Camaro SS M6 w/LT4 (Sold)
travislambert is offline   Reply With Quote
