Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Tuning / Diagnostics -- engine and transmission
Old 06-23-2010, 12:20 AM   #1
Mr CLuTcH
Always On Kill!
Mr CLuTcH's Avatar
Drives: S.I.M. SS
Torque Management?Top Speed Limiter?
I've looked up many different tuners to buy for my L99, but I can't decide on which one. All of them claim to be able to "turn off" -"torque management" and "top speed limiter" and also "Rpm rev limit".
What is really going on when you turn off "torque management"?
If you turn off your "top speed limiter" is is possible to reach speeds past the limited 155mph limit, such as 180 on the dash?
What are the effects of changing your "RPM REV Limiter"? Is doing this safe for your engine? Will I be able to reach the "red zone".....or will I need a maggie? lol.
S.I.M. SS(L99):
*American Racing Headers (LT)
*Magnaflow cat-back competition exhaust
*K&N typhoon CAI
*Aggressive cam.
*Tune
**Result**: 465rwhp/ 447rwtq. Satisfied.
Mr CLuTcH is offline   Reply With Quote
Old 06-23-2010, 05:54 AM   #2
Diabloformula
Diabloformula's Avatar
Drives: 98 Formula
Basically you're just telling the ECM that there isn't any TQ limits to abide by, thats why everyone maxes them out, who wants a someone telling you how much TQ your car can make safely.
Yes, with the right gearing and tires you could reach 200+mph with the speed limiter turned off.
Unless for some reason you are making power above the recommanded RPM (from a cam for example) there is really no need to change this. It is safe as long as you have the parts in place to take the higher RPM such as valve springs, pushrods, etc. You can set the RPM limiter way past the "red zone"....but if you like your engine, probably not a very good idea to do so and a maggie will make power in the lower/mid RPM range not up past your red line like a turbo or centrifigual supercharger.
DiabloFormula Racing
98 Arctic White Formula.M6.VooDoo 222/228-.567"/.567"-113.Boltons.NOS.
Midwest Chassis Fab 9"/Braced/Geared/Fire Engine RED
N/A 391.33rwhp/353.13rwtq -501.56rwhp/462.67rwtq Slipping a 150 Shot
N/A-11.587@120.96 1.69 60FT /150 Shot-10.860@129.01 1.54 60FT...so far.
Diabloformula is offline   Reply With Quote
Old 06-23-2010, 08:05 AM   #3
DSteck
Drives: 2006 Corvette Z06
Eh, sort of. The main purpose of torque mangement is to save the transmission from certain doom during shifts. On an automatic, it also serves to help the transmission complete it's shift without flaring.
The car would also need a lot more power to break the 200mph barrier. It's too heavy and doesn't have anywhere near efficient enough aerodynamics to touch 200mph.
Agreed... Plus, on an automatic car, a rev limiter increase won't do much unless your shift points are raised as well.
DSteck is offline   Reply With Quote
Old 06-23-2010, 09:05 AM   #4
Duke
Duke's Avatar
Drives: 2010 Red SS/RS
So, how much can you safely reduce TM? 50% TM...25% TM? I'm sure GM has tons of safety factor in at 100% TM, so what is really a safe %. The G8 guys have logged more hours on the A6, would that be a more valid source of data?
Duke is offline   Reply With Quote
Old 06-23-2010, 11:48 AM   #5
DSteck
Chief Blackhawk... aside from a quick cursory look, no. I've been so damn busy lately. :( Send me your new one, I'm curious what you've changed. Did you go with a single or triple disk converter? Any problems with lock-up at steady cruise?
Duke... 50% seems to be a good reduction for WOT. I wouldn't take everything out unless you're cool with the possibility of wrecking your trans (despite however many people say they eliminated it completely and have zero problems).
NEW HAMPSHIRE Members... Sound off! FiLTHy PHiL SS/RS USA - New England 332 07-24-2012 09:53 PM
ProTorque Converters - FREE Shipping! tbyrne Transmission / Driveline 0 01-07-2010 12:36 PM
Whats the speed limiter set on the ECU? FutureCamaroOwner 5th Gen Camaro SS LS LT General Discussions 4 12-30-2009 03:21 PM
Cam Headers Intake Tune 446 RWHP 430 RWTQ JANNETTYRACING Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 72 11-25-2009 03:09 PM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 10:06 AM
