07-09-2022, 04:31 PM | #1 |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
How much faster is the A10 over the M6 in the 1/4 mile?
I notice all the open mod 1/4 mile times for the ZL1 are held by automatics. Just curious, in the hands of a capable driver, how much slower is the M6?
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 |
07-09-2022, 07:10 PM | #2 |
The A10 is .2 to .3 quicker, depending. What power are you making and what times have you run?
'20 ZL1 1LE A10,
07-09-2022, 07:17 PM | #3 |
Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
This is a tough one to answer considering how much easier it is to 60 foot an A10. I think generally speaking .2 - .3 sounds good.
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
07-20-2022, 10:29 AM | #4 |
2Spdsy
Drives: 2021 Camaro LT1 A10 Join Date: Mar 2016
I would say it’s closer .5 because the a10 not only launches better but helps to keep the engine in on the powerband . My buddy has the same mods as me , same weight reduction . We dynoed the same and he’s 3-4 tenths slower then me in the 1/8 mile and 5 mphs slower .
Amd he’s a good driver . |
07-20-2022, 03:46 PM | #5 |
Drives: like an old lady Join Date: Jun 2012
i agree with this. in the hands of a capable driver, a difference of 2 mph at most.
07-20-2022, 05:34 PM | #6 |
This will be amplified the more a car is modified and the higher it traps. If you ever look at 1/2 mile traps of modified ZL1’s there is a 10 MPH+ difference at ~900 RWHP.
07-20-2022, 07:38 PM | #7 |
yes i thought of that after the fact. more power the bigger difference.
07-22-2022, 10:03 AM | #8 | |
Obviously, this means that a 'capable driver' can only do so much when the computer has this problem, because the driver does not truly have control of the car. Yes he/she can launch at 4000rpm while stock, and even more rpm when tuned, but after clutch engages, the computer gets mad and pulls power out. |
07-26-2022, 11:18 AM | #9 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Hero run vs Hero run might be .3 and 2 mph but compare the average time for both and it will be .5 second difference.
Reason being M6 is difficult to run consistently compared to A8 Run on sentences I know
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
