09-10-2011, 09:57 AM | #15 |
Drives: CTSV Join Date: Feb 2011
Valve train is key
Plus the right connecting rods 2 of the most stressed areas in a engine. Add $$$$$$$$ |
09-14-2011, 05:53 AM | #16 |
Drives: 2010 IOM 1SS M6 Join Date: Jun 2011
Ted and Meister,
Thanks! |
09-17-2011, 07:49 PM | #17 |
Drives: Exige, Miata, Ghia Join Date: Jun 2011
What is the highest safe rpm on a stock ls3 without factoring in the rev limiter?
09-19-2011, 08:03 AM | #18 |
Without better valve springs 6800.
www.jannettyracing.com
01-08-2015, 06:31 PM | #19 |
Drives: red camaro ss 2010 Join Date: Dec 2013
And with bt 660 lift springs With a .649 lift cam? What would be safe rpms to not get valve float or damaging heads on a a6
mods: ported tb,1 7/8 TSP lth, adm Cai and scoop, 3:73 gears,exhaust and RPT Tune.
best time before headers: 12.6@111 |
01-08-2015, 07:53 PM | #20 |
Eh, that'll happen
Drives: 2010 2SS Join Date: Apr 2012
You also have to remember that Lambos and Ferraris all run flat plane cranks too. Thats where they get their high revs from. Fords new GT350 is running a flat plane crank and makes peak power at 8200.
2010 Camaro SS LS3 - No Modz
01-09-2015, 08:22 AM | #21 | |
Cam Ramp profiles, Cam specs, weight of valvetrain parts, type of rockers and a host of other factors all play a roll in what max RPM you can spin the engine. Most cams for these engines will make peak power between 6200 and 6800 RPM Shift points should be about 10% higher than where Peak HP occurs for best performance. Rev limiters are there in the event of a missed shift and are not to be used as a parade device. Yes believe it or not some cultures use the rev limiter in a parade. Ted.
01-09-2015, 09:58 AM | #22 | |
Boosted Moderator
true...
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
What do all the abbreviations mean? | CrzyGamr2 | 5th Gen Camaro SS LS LT General Discussions | 77 | 12-07-2012 04:34 AM |
my dyno today(base for e85 tune) | bmorecam | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 51 | 06-08-2011 11:35 AM |
LT1 Rev Limiter Problem at Track | GRSCAMARO | 4th Generation Camaros | 9 | 04-25-2011 12:00 PM |
rev limit for v6 | youngkim | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 1 | 04-08-2010 11:13 PM |
Whats the advantage of high revs with the same power? | DGthe3 | General Automotive + Other Cars Discussion | 29 | 04-02-2008 11:19 PM |
