09-18-2020, 12:00 PM | #1 |
Drives: 2013 SS/RS, 2015 Camaro SS/RS Vert Join Date: Sep 2019
HOLY CRAP - You never want to see...
...your entire rear, passenger tire go peeling off in front of you at 80 mph.
Just got towed home. The thing I can't figure out is why my brakes went away when it happened. I had to coast to a stop on the side of the freeway. I'm sure we'll find out once we get in there later and start poking at it. But it was weird AND scary, I have to say. On the plus side, while I was crapping my pants during the ordeal, the Camaro tracked amazingly well, considering the tire had disappeared. |
09-18-2020, 12:09 PM | #2 |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
Wow, glad your ok!
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
09-18-2020, 12:10 PM | #3 |
Drives: 2014 2LT RS Summit White Join Date: Apr 2017
Yikes, amazing the car emerged mainly undamaged. My guess is that the tire took out a brake line and you lost all your brake fluid and that was it for the brakes. It sure could have been a lot worse.
09-18-2020, 12:13 PM | #4 |
09-18-2020, 12:14 PM | #5 |
Yes, got very lucky. No visible damage to the body or fender well. Wheel got some nicks but not bad either. Buuuutt...it may be my excuse to get a nice aftermarket set now...grin...
09-18-2020, 12:33 PM | #6 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
Any drive you can walk away from was a good drive.
Any drive you can walk away from and still use the car again was a GREAT drive! Glad all is reasonably OK! |
09-18-2020, 12:36 PM | #7 |
Drives: 2011 Camaro SS Join Date: Jul 2019
That's an incredible pic. I didn't think that was possible. Contact the tire company and say you had a problem. haha
09-18-2020, 12:53 PM | #8 |
Drives: ABM #93 Join Date: Oct 2018
Damn danial glad your ok. Could have been way worse for sure.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
09-18-2020, 12:55 PM | #9 |
The roads are brutal here in SoNev but I am surprised that this Cooper tire didn't hold up longer. They were put on the car last summer just before I bought it and they have a date code of Jan/19. There's about 16K miles on them. I'm going to have to rethink Cooper if this is the kind of product they produce these days.
09-18-2020, 01:12 PM | #10 |
Thanks for the well-wishes guys. Headed out to remove it now that I have changed my shorts. Tire shop will have a replacement for me tomorrow.
09-18-2020, 01:40 PM | #11 |
Damn brother! That's all those monster rips you are letting your granddaughter do!
JK. Glad you are ok man. That could have ended badly. Man those Coopers have a stiff sidewall. It's still holding the rim off the ground.
09-18-2020, 02:07 PM | #12 |
Wow Danial, so glad you are ok and the Camaro isn't damaged and you got her stopped alright. This happened to a friend of mine on his Charger and wasn't so lucky, totaled the car. Good luck sir!!
09-18-2020, 02:30 PM | #13 |
Drives: 2014 Camaro 1LT Join Date: Aug 2019
Dude, that's messed up. Where'd you get those tires, and what are they rated? Do you do a lot of pulls and heavy driving, or is this just a defective tire (or a combo of both since tires shouldn't rip apart at 80 regardless of how hard you have been driving before)?
09-18-2020, 02:53 PM | #14 | |
Seriously though, I can count the number of times on one hand we've done burn outs with the car. I'm just not a big fan of that. And yeah, how 'bout that sidewall? I coasted on that for probably a quarter mile too, before coming to a stop. Too bad the rest of the sidewall wasn't that tough. |
